0 Members and 120 Guests are viewing this topic.
FreeEnergyInfo
Zeitmaschine
OK, here comes the next foolish assumption of mine: The primary coil of the transformer in the 2004 video ... is it connected or is it not? I can see something that looks like a wire coming from the primary coil. But I can't see any wire(s) going from the primary coil to the two solder terminals. The solder terminals are mounted on a Bakelite strip. This Bakelite strip is screwed on tightly on the transformer's iron core, so there is no room for a wire between the strip and the iron core (the wires would be pinched). On the other hand I can't see any wires leading to the primary on top of the Bakelite strip either. What does this imply?
Is the primary coil of this transformer connected at all? Or perhaps both solder terminals are used for the white cables only? Then this would signify that this transformer is not a transformer but a choke, because only the secondary coils are in use.
This idea is just to to ensure no odd theory is missed (and thread stays on top) ... :)
Vasilius
Coaxial inductor as capacity, or the coaxial capacitor:
http://youtu.be/hMvuB5_oIWU
Has noted such detail. The coaxial capacitor is charged at a certain backlash from the hot end (about 1 sm). Though sparks it is not visible a capacity charge goes. At the big distance "coaxial" it is not charged. At smaller distance it is visible a spark, but it consists as though of two sparks. As in a lightning the first leader who charges the "coaxial", the second streamer which here discharges it. I.e. "coaxial" was charged and here was discharged. The high-voltage column from the diodes, switched on consistently with "coaxial" has helped in this case. The "coaxial" discharge through winding THVL (Transformer High-Voltage the Line scan) has stopped, "coaxial" was charged much more effectively.
Has drawn a lead-out, that at a correct backlash the discharge device works as the high-voltage diode.
Translation from Russian the translator.
xenomorphlabs
Quote from: a.king21 on November 03, 2012, 06:02:50 AM
All I see here is pencil engineering.
The scope shots are wrong for fe.
I won't be wasting my time on it, although the inverter seems a nice project, especially as I've destroyed several.
Exactly.
No revelation in all of it.
It's just a bunch of copied incoherent schematics from various russian sites including
Don Smith interpretation circuits that don't work and a depiction of Hector's Diode plug without any credits to him.
Who is able to combine all of that mess to a working circuit with significant C.O.P could as well do it without it , because you gotta know exactly what to do
without being distracted by 10 different approaches.
FreeEnergyInfo
