0 Members and 133 Guests are viewing this topic.
the_big_m_in_ok
amigo said:
Oh, and by the way, this also popped up on one of the Russian forums, although they knew about this setup for awhile (couple of years), this is just a nicer graphics and a more recent version.
Having seen the picture, I would theoretically remove the ferro-resonant silico-iron transformers with toroids and see what happens to the output power compared to the original design.
--Lee
grizli
Quote from: armagdn03 on April 17, 2010, 01:57:11 AM
and predictably, the thread sinks back into oblivion....
good luck....and god speed... im out......
You havent commented what I said, please do
grizli
Quote from: Omnibus on April 17, 2010, 08:44:28 AM
It seems there's a massive obsession with dead-end issues such as Tesla ideas, energy from the vacuum, resonance etc. It should be understood that resonance, for instance, by itself cannot be a mechanism for OU.
What are you new dogmatic priest or what ?
Paul-R
It seems there's a massive obsession with dead-end issues such as Tesla ideas...
Gordon Bennett.
armagdn03
Quote from: grizli on April 16, 2010, 05:35:17 PM
SO.. question for all !!
Lets make TC with concentrated parameters.
we DONT have elevated capacity, we have tunable capacitor between both secondaries (reciever , transmitter) and other ends of secondaries are connected together
Low turn(5 turns) of 1st coil is LC resonance ,  transmitter and reciever are L+L=2L and they make 2LC resonance ... frequency must be tuned of both LC resonators..
around second coil there is also low turn wire.
Putting resistive load or even shorting the wire will reduce reciever inductance by "transformer law"(back emf) but we just tune series C to match low turn wire resonance ..
IN ANY WAY feeder 5 turn coil SEES NO LOAD ... BIGGER the high turn wire inductance bigger the Reactive energy inside!!!
THIS WAY WE HAVE 1:1 transformer effectively . and primary fluw has nothing to do with secondary flux
PROVE ME in theory  or in  experimeny that I am WRONG .. !!!!!!!
If this is the quote you wanted me to comment on....
Sounds interesting, I will give this a small go, and report what I find, I have everything needed on hand.
I wish I could turn my brain off sometimes, then I could get some sleep.
