0 Members and 1847 Guests are viewing this topic.
jbignes5
Quote from: zcsaba77 on February 13, 2013, 08:12:17 AM
hi
what is oil's function? cooling? enlarging magnetic field?
Yup the oil is a dielectric. It keeps the air displaced around the coil so the air can not break down and cause a discharge which could damage the coils. I would suggest oils over solids because they are very dynamic. This allows a better dielectric coverage then say a solid in between the winds of the coils. Applying heat to the oil allows for more complete saturation of the wires in the coils and hence less of a breakdown occurs and the device is capable of extremely high output when compared to normal coils.
A type of transformer oil is used by the electric companies for thier transformers. Most used to have PCB's in the oil which now they have replaced with friendlier oils.
If you read that lecture I posted, It will tell you about the construction of the transformer and any improvements Tesla thought relevant, Like metal shielding around the wooden box.
zcsaba77
Quote from: jbignes5 on February 13, 2013, 07:58:27 AM
The oil allows the voltage to max out without a breakdown occurring. You need to make sure there is zero air in the coil box or the coils will break down and destroy themselves. That's the reason for the oil bath.
You mean fully immersed both coils in oil? That was Tesla's electric car's power supply?
jbignes5
Quote from: zcsaba77 on February 13, 2013, 09:35:46 AM
Yes the coils need the oil bath. Also you will need to statically shield the wires connected to each terminal. Only let the wire be exposed without the shielding when you want the movement of the field to interact with air or objects. This interaction is the excitation of that object into a harmonious current flow. The type of current is either all going one way or cycling in and out of a hose.
It only needs a kick start then goes into oscillation and then over oscillation then back to regular oscillation. This regulation is an automatic feature of resonance and segmented matter. As long as you observe the rules it will last forever or as long as the material can hold to the stress this kind of energy imparts through the excitation field.
To strengthen the effect you need to get rid of all magnetic interactions when releasing the electric bursts. This requires using ferris matter inside of the heavy copper tube. An electric field made with very little current before the break is a much different type of arc or spark then a heavy current arc or spark. The difference is weather there is a magnetic component mixed in. We want a current less spark or at least the smallest current to jump the gap and energize the heavy copper coil of the TK'S converter. I highly suggest  using ferris material in the pipe. This draws all the magnetic field into itself and only the electric field is allowed to exist and condense. Once the fluid like condensation masses you can use it to generate huge movements of current in matter. This is done by resonating the materials base frequency and based on any induction laws that would apply. These include static based induction rules.
I highly suggest you be very careful building such a device. Respect the voltages and make sure you follow proper safety guidelines for current understandings of high voltages. Frequency is also a very important safety concern But as Tesla figured out the higher the frequency the less apparent the effect on living matter it has. I say apparent because we don't have a lot of data yet on the effects. Tesla reported that 20k cycles was pretty benign. Mostly atmospheric in nature like spontaneous light and cool breezes and warm ones as well.
So try to start at 20k then work up from there. Tesla said the efficiency of this pump/exciter can get quite high due to increased frequency=increased power effects observed by Tesla.
Here is a little bit of information on Dollard and how he see's the science of today. This is a logical approach and riddled with facts they can not refute.
http://m.youtube.com/watch?v=GObB67ETvRQ
andrea76
Quote from: idzaza on November 14, 2012, 08:12:04 PM
How do I translate? write here what he is saying? I'll try my best, word by word.
From the beginning he is complaining about the government/bureaucracy. He was expected some other people to come but they did not come.
Starting about the device 07:00 minute. Note:The green inverter you see is made in Armenia, it is the inverter and the charger for the 12 volt battery. Using that device you get from 12 volt DC 220 volt Ac 400 watts.
TK - this car battery is almost died, it does not hold charge, so he is saying that if the car battery is fine he would not need charger.
Guest "X" who came for the demo is saying that he does not want it to be switched on, he is asking to explain how the device work.
Tk - saying that firstly when it starts working, primary coil gets power through spark gap.
TK - saying that in the spark gap interruption happens 50 times in one seconds. He is saying that in the spark gap is 50 Hz
TK - saying that the thick wire is the primary coil. He is saying that the most interesting thing is that the spark gap takes very little power. Then he is pointing finger on the inverter saying this is 400 watts inverter, but we are receiving 5 kilowatts from my device. 400 watts not fully needed. we are taking about 0.4 amp which is 40 milliamp, getting 5 kilowatts. I simply started charging battery from the output energy, today scientists colling this perpetuum mobile, when from the output energy battery gets charged and the device is feds itself. I did the test, output for charging the battery I disconnected from the battery and it worked from its own output power. The device works, gives 5 kWatts and just takes from the output what ever it takes 0.4 amp. So, this is the very positive result of this device. takes less and gives much more.  Now I do not know its max power output, it might give 6,7 8, kilowatts but at the moment I do not want to risk to burn anything, basically 5 kilowatts are enough. It needs about 0.4 amp 220 volts and gives about 24 amp 220 volts. This is the secret(not really the exact word, but is very similar) of this device.
X - is asking, why did not you try in the vacuum when tested in the factory like everything in one box
TK - It was not convenient to put all together, because we where testing the device in the factory (the factory he mentioned is in Tbilisi, this factory used to produce war planes, I think tanks etc during soviet union and later too, I think it had wide profile and I think until now it is called 31st factory). If there was some details to replace or upgrade was not convenient to have everything in one box. We put all mechanism on the vacuum, the mechanical mechanism was turning very well in the vacuum but then the electric device was getting hot. During the test some managers made me angry and I left the factory and started working on this device to improve it, I did not expect but here we are, as you see the result exceeded my expectation. He is saying the that mechanical device was giving 3-4 times more power/torque than without vacuum.
TK - This is better just this device, god let us all have it, if anyone wants to use it, it is here. He is again about the government - I do not understand what they want, I am offering such things that any normal thinking man wont say not interested.
TK - pointed to the man saying we tried in his garden just with one kilowatt generator, whole garden was bright and we let running long time without problem, someone called Mamuka came, he is physicist, I(TK) asked him can you explain you as a physicist all these, Mamuka answered that he is not sure, he does not know, this is not something I can explain by simple physics.
These what I see exceeds law of Physics. This is something retailed to some kind of nature I can not explain now, I do not know. This is impossible, I do not believe, there is something I do not know what?.
TK - Why? here it is. why is it not possible? when was these laws established? in which century? 18th century? He is asking to explain by physics laws, If I brake any law of physic's when you see her this device why does it work? I am not braking any of laws of physic's in this case leave me and trust in what you see and try to understand.
Mamuka - what can we do, this is not by the law of physics.
TK - in this case update it.
Mamuka - No you are crazy.
TK - here is the experiment I conducted for you, and did it many times, in many places.
Mamuka - If you can, explain it if not we can not recognize it.
They are discussing different physicists reactions which happened in different times.
Some othe physic said to TK, we understand there is unlimited energy in the cosmos, but what it has to do here, what is it, is nothing emptiness?
TK - where is our earth? is not it in cosmos? Are not we part of the sun system? don make me mad? One came and told me who are you to ignore the power of gravity?
TK - When did I say? who did I tell that? where is it written? show me, I have never said that. He repeated the same question, I asked him did you read the theory of (some kind of polarity do not know its translation, sorry). The man got red on his face and did not say the word and left me. One big physic came to me and told me, lets write a theory, I'll be your co author.
TK - is asking camera man to get closer to the device, as a source of power i use car battery. Battery powers inverter, from the inverter the device starts working. Let see, and he turns the inverter on. Battery is died, has maybe 11-10 volts, but one little kick will do, he plugs the inverter into mains and said the sparks started.
Persona X - Will this spark stay if you unplug?
TK - yes, I unplugged just now and it works from the battery. Switch it on (he means bulbs, each is 1 kilowatts, has 5x200 watts spiral in it. He ask to measure the input amp and output amp. it takes 00.4 amp and gives 25,4 amps.
TK - lets do the experiment. lets plug the battery charger on the device output power. Do the way everyone can see. This is 0-negative the other one is positive. Now I will plug the charger to the battery to charge. I am conducting the test, the battery anyway is giving the start up energy, but later after whenever it will be discharged if not charged. we try to charge the battery from the energy we get out of device. the battery does not have enough power let me for a second plug to the mains. Ok, now the spark started, unplugged and works. measure it now. What we use and what it gives. 0.2 amp 0.3 amp. How much takes battery charger, let me see, 2.8 amp, 2.7 amp, 2.6 amp. How much is from the charger to the battery 6.5, 6.2
Next let do like this, if can charge the battery from the received energy, the battery supply inverter so that is how it works. untill the battery lasts without the charger the device will work. now we are charging battery and I am going to remove the battery. I removed the battery, but now we need the start up energy. that is why I am going to use mains just for start up. as soon as I get energy from the device we do not need the mains power anymore. look now I am unplugging, see we are not getting any power from anywhere other than from the device which feds itself. I could remove the inverter and charger and just will need a start up energy sours. That I will do later. the bulbs are very bright and keeps as long as you want.
X - Can you start up one more time?
TK - Yes, will do. so that's it. OK now you want me to unplug the device from the inverter and see how long it will last on its own, let see what happens. last may be a second or two.
X - saying, it lasted for some time, might just need some technical improvement and cold be working on its own.
XX- the fuck is here, It is working, I can not deny the fact. I have nothing to argue. many things can be argued, but here is no theory.
TK - we may argue about the theory I have and write you could argue some things can be improved father, we may discuss the better scheme, but this is what I have now and is fact. Something should happen, they are just joking about something irrelevant.
X - so we had exclusive for video.
TK - No, I need video to be done for the Internet, so many people can see. Please, would take a video of the scheme/device properly come closer please.
Camera man - yes will do one by one.
TK - let me give a space - please do what you need.
I did my best took me over 1 hour.
Thank you and hope this helps. Try to do not judge me. English is not my first language. It is my fourth.
It seems to me not to be too complicated. I am not in Georgia, have been in UK for few years now. When I get there this Christmas, I'll try to find out about Tariel and his devices as much as possible.  :)
can be the spark gap/thick coil only a static discharge??..... BUT the "process" use 50hz to commutate the DC ..mmm..
a.king21
Quote from: andrea76 on February 13, 2013, 03:27:34 PM
Thanks once again Andrea, the original is an extremely useful post and puts the skeptics in their place.
Obviously TK conquered the looping problem later.
