0 Members and 472 Guests are viewing this topic.
jbignes5
Quote from: semenihin-77 on February 14, 2013, 06:30:27 AM
Energy from the Earth  :)
https://www.youtube.com/watch?v=B8Y6sQR-d0A
Current from the ground. It works!
http://www.youtube.com/watch?v=jQDz20bDd2g
I like this one but there is not enough compression in the engine department. With a little more bang in there that thing will really power something. We have to remember the leaking energy and how to plug those leaks. Once you do it will be like a power washer with no leaks. Right now your energy is leaking from every point and it can not gain momentum.
stivep
http://jproc.ca/radiostor/aalt.html
quote:
QuoteOn October 17 1996, between 0900 and 0930 hours UTC, it was planned that the Grimeton alternator would be used to send test transmissions on 17.2 kHz
Schumann frequency that makes triggering lightning around the globe.And trasition of  huge energy due to electromagnetic resonance and it does not have to hapened in primary but also in secondary harmonics
http://en.wikipedia.org/wiki/Schumann_resonances
with ionosphere and earth acting as waveguide
The shape of this waveguide is circular! closed loop.
At that point interaction between natural lightning  AC( after lightning occur)and any other modulating or influencing signal might be created.
If resonance is to be reached it will happened here in secondary harmonics.
the level of interacting  factor is not important.
Example:
Power needed to open valve with  big water pipe by hand makes  energy ( water) flow and we do not care who pays for that water as we do not care about  big "pipe" of solar energy at every second bombarding   earth ( huge energy in total.)
What we doing now with our solar toys panels is like immersing probe in waveguide  just to see some fraction of it.
But resonance makes you experiencing  unpredictable concentration of it in one point of many.
Schumann resonance is not limited to
7.83
The higher resonance modes are spaced at approximately 6.5 Hz intervals,[/size][citation needed] a characteristic attributed to the atmosphere's spherical geometry. The peaks exhibit a spectral width of approximately 20% on account of the damping of the respective modes in the dissipative cavity. The 8th partial lies at approximately 60 Hz[/size]
wikipedia.
QuoteThe cavity is naturally excited by electric currents in lightning. Schumann resonances are the principal background in the electromagnetic spectrum[/size][1] beginning at 3  Hz and extend to 60 Hz,[/size][2] and appear as distinct peaks at extremely low frequencies (ELF) around 7.83 (fundamental),[/size][3] 14.3, 20.8, 27.3 and 33.8 Hz.[/size][4][5]
17khz of Alexanderson is far from Shumann but talking about lower  harmonics of 200kw transmitter and arials of antenna it might  be influencing
The anntena gain makes this power to  be multiplied to hundreds of kw
From another hand:
lightning is consisted of all of the spectral components of spectrum from Schumann resonance  to light .
quote:
Later Divya (1986) measured these polarized components of electric fields at 5.00 kHz
and from this obtained the value of soil conductivity
The lightning electric field is measured in the VLF range by using a broad band receiver. The
vertical electric field component is measured by a vertical wire of height 10 m and radius 0.125 cm.
The antenna is not loaded on the top to present the coupling of the horizontal component with the
vertical. The signal is amplified and fed to the recording unit.
is that the TK antenna like structure
Results and Discussion
Fig. 1 is a typical example of the frequency spectrum of the individual pulse of atmospherics in
the horizontally polarized component. The spectrum peaks at 8 kHz after which it falls off abruptly,
remaining almost constant above about 55 kHz. Fig. 2 is a typical example of the frequency spectrum
of the individual pulse of atmospherics in the vertically polarized component. In this case the peak
occurs at 5 kHz. After the peak it falls almost exponentially which negligible small field strength above
about 40 kHz
17khz of Alexanderson  is VLF
http://www.vaisala.com/Vaisala%20Documents/Scientific%20papers/Horizontally_
and_vertically_polarized_components_of_lightning_electric_fields.pdf
does Alexanderson disc remainds you TK motor?
http://www.flickr.com/photos/jdredding/2941592076/
http://www.flickr.com/photos/jdredding/2941592334/in/photostream/
interesting image
http://www.haikuvalley.com/History/THE-ALEXANDERSONALTERNATOR-AT/539611
_mgBq22/62107948_2phcDND#!i=702950436&k=WxhnKdg
Two of the four helix coils are visible here. They were part of the antenna tuning system. The dark object between the two coils is a transmformer that either further adjusted the voltage or assisted in tuning. More research is required. The view is to the west.
By 1946 the round opening and attached antenna had been eliminated and the antenna went out an identical opening on the east side of this helix room, located on the second deck.
Look at  TK tent .
At  picture at the bottom alexanderson 2
You see some of notes.
Was that the problem of TK when one of motors becomes overheated?
The mechanism of extraction and amplification is based on magnetic amplifiers
to say it simpler
transformers.
update to original text"
http://books.google.com/books?id=la0oAQAAMAAJ&pg=PA26&source=gbs_selected_pages&cad=3#v=onepage&q&f=false
http://www.patent-invent.com/inventors/ernst_alexanderson_patents.html
Quotequote:Magnetic amplifier (mag amp). Magnetic amplifiers were important as modulation and control amplifiers in the early development of voice transmission by radio. A magnetic amplifier was used as voice modulator for a 2 kilowatt Alexanderson alternator, and magnetic amplifiers were used in the keying circuits of large high-frequency alternators used for radio communications. Magnetic amplifiers were also used to regulate the speed of Alexanderson alternators to maintain the accuracy of the transmitted radio frequency (see also US patent No. [/size]1,206,643[/size]).[/size]
http://books.google.com/books?id=la0oAQAAMAAJ&printsec=frontcover&source=gbs_ge_summary_r&cad=0#v=onepage&q&f=true
Wesley.
PS: stay at previous discussion  of magnetic flux
http://www.youtube.com/watch?v=SHbQXnXK6Xc
That is something in it.
jbignes5
 Just Remember that we want to separate the forces that make up electrical phenomena. The magnetic will never do anything for us. This is because it is circular around the wire. The in and out is always voltage field base. Since we can raise the voltage with a corresponding lowering in the current this reduces the losses associated with heavy currents and magnetic forces.
Since the voltage field is at right angles to the plane of emission then this means it is the way to energize the inner conductor and attract the magnetic field that is associated or tied to the electric field. This will borrow from the environment what magnetic field our devices need and convert them into other forms of energy like heat and light or even motion.
The emitter it seems must be a segmented coil and should have ferris material inside of it. This allows for the magnetic field to be channeled away from the attractive electric field as it forms. Since the electric field is in motion we are trying to harvest the current from that motion. When matter is introduced into this field it gets energized and if that matter has segmented portions then it will increase and polarize the voltage exciting field around the matter.
My first steps in this area will be with creating the oscillator. I think I'll go small at first until I get the hang of this new setup. Just remember that we need to apply fluidic laws to these new oscillators. The outputs will be very leaky if you do not use the Tesla method for statically shielding the output wires. Only one output wire needs to be utilized so testing which end either a pressure or vacuum wil form. I assume the pressure will work better but that remains to be tested.
My earlier shielding ideas will have to be implemented as a safety containment around the converter. As long as we do not go over the capability of the metal of the self terminated coils we should be fine.
I'm seeing all kinds of possibilities for this new type of fluidic technology. Can't wait to get into my new lab.. Got a few more months before that happens.
Grumage
Hi All, I dont want to put a dampener on this one, but have a really good study of vid No 2. The circuit diagram clearly shows the 15 watt bulb in paralell with the output transformer. In the video I cannot see that physically. What I see is a white wire dropping down behind the transformer and a small brown wire dissapearing to the left under the DVM below what I assume is the earth wire.
Put me straight?!!!
stivep
Quote from: jbignes5 on February 14, 2013, 04:11:21 PM
imagine that you chapping magnetic filed at 90 degrees
with blades  of fan
would you have variation of electrical properties in primary device?
would that contradict
quote
QuoteThe magnetic will never do anything for us. This is because it is circular around the wire.
The same effect can be created with additional coil placed at 90 degrees with square signal on it instead of  blades of fan
Always gets me into thinking of NMR fundamental orientation of coils.
Wesley
PS: picture below should be named 90 degrees not 80
