0 Members and 346 Guests are viewing this topic.
znel
Quote from: baroutologos link=topic=7679.msg240898#msg240898 A=1273428961
@Znel,
Dragon is that you? I remember your observation and setup as you explained it. The point is do you have any hint that the 15Hour of oscillation is more A than that contained in the cap initially?
Something similar to Dynatron, i have experienced with my Ignition coil when the spark-gap is way too wide to spark, so cables are electrified and spark slightly for some time. I have not given any particular attention :)
I don't believe it's anymore energy than was placed in the system originally.   Yes, I post as dragon on the energetic forum.
You can, however, get some interesting results by driving a transformer or other load with the cyclic behaviour.   I plan to post some interesting experiments I've done with the Kapanadze, Smith and Marks circuits on the energetic forum in the near future.  I believe their all related to some degree.
I believe the secret is in manipulating the voltage and amperage within the system.  Such as controlling the amperage by the values of C and L in a tank circuit.    V*(C/L) = amps generated in a coil from a spark gap.  It's really not difficult to manipulate one or the other but to combine the differences becomes quite challlenging.
Last summer I was playing with shorted rings through a toroid and how you can manipulate the resonant magnetic field by altering the load on the rings without disturbing resonance.  Also creating a parametric feedback that would help add energy to a system.   A few days ago I decided to follow up on that work and built a circuit that would operate at 3 distinct frequencies.   I don't believe it's OU but definately an excellent demonstration on recycling.
The pic below shows the scope shot of that cirucit.  Notice the 3 distinctive frequencies.   The large spike is the PWM controller input, the long ring down is the large ring oscillator and the last input of energy is casused ( I believe ) by feedback from the main coil where it tries to re-start the main ring oscillating again.
Odd how the first of the last 3 large ring downs seem to have almost as much energy as it started with at the beginning of the first ring down... where did that energy come from ?
baroutologos
I thought it was you ;)
I have the lowest hopes of OU or even energy recycling with an end at extracting more ergo per joule imported to a system by using LC resonance. From my so far experimenting this is not suggested under no circumstance.
By the way, i would be happpy to see your setup, investigate it and potential replicate it within this scope.
baroutologos
I keep watching habbitually videos of kapanadze green box device and SR's.
Both use ground. SR claimed that ground is for RF production/absorbment. kapandze device on the contrary ground thick cable measures 20 amps!
Something is not correct here.
forest
Maybe frequency is different ? I recall user bolt talked about that. With low frequency 50-400hz energy is pulled from ground while in khz it is taken from air. The same was Don Smith talking about.
baroutologos
Ok assumming you can pull charges somehow of that quantity.
Where are you going to store them?
