0 Members and 400 Guests are viewing this topic.
Hoppy
Quote from: Сергей В. on April 14, 2013, 12:16:32 AM
Всем Привет
to Stefan H., NickZ, verpies, Wesley and all on this forum
My advice is translate this and try to understand some incontestable facts !!!!
Wow- Horse s..t - the secret to free energy. Its starting to smell sweet around here!
verpies
verpies
Quote from: NETIKS on April 13, 2013, 09:11:03 PM
Its Easy to detect neutrons with PIN FOTO DIODE radiation detector  ;)
Yes, but currently it is impossible to buy such boron laced PIN diode.
Making a PIN diode out of hydrogenated amorphous silicon in a typical garage is difficult for most people.  Who has a chip lab in their garage?
Solid state neutron detector:
http://www.faqs.org/patents/app/20110266643
Cosmic Ray (Muon) Detector using Si Pin Photodiode:
http://hardhack.org.au/cosmicpin
http://www.vk2zay.net/article/265
http://www.youtube.com/watch?v=wl-UggVIDuA
Those three devices will not detect neutrons.  Others - yes.
verpies
Quote from: NickZ on April 13, 2013, 10:48:30 PM
Wouldn't it be wiser to first see if there is ANY USEFUL output, before getting into all the types of radiation that can or can not be detected, by test instruments.
Not really, because radiation is a more direct measurement of the anomalous stimulation of nuclear decay than electric output.   Radiation is not electric current and cannot be measured with a multimeter.
For example beta electricity has to be directionalized first in order to constitute electric current, and that adds more difficulty to the experiment (more variables to get right).
GM tubes are cheap, for example see this: http://tinyurl.com/GMTubes
Using one of these is much cheaper and quicker to confirm the anomaly than going the extra step to directionalize beta particles into electric current or make a Direct Charging Generator or a nasty thermal conversion.  Something can always go wrong with this conversion to electric current.
In the Colman device maybe the conversion of induced radiation is already converted into electric current by the tube's design, but would you like to miss your correct RF frequency (f) and magnetic flux density (B) if it so happens that everything works except this additional conversion process ?
The conversion mechanism introduces many additional variables (e.g. the conductivity of the powders or correct tube diameters, layer thicknesses and densities) and if you get any of them wrong then you will not be informed by your multimeter when you tune the correct f and B, however the GM tube will give you the feedback more directly.
NETIKS
VERPIES
If it can detect muons it will detect neutrons also just You need array of these diodes BPW34 its cheaper than GM tubes
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=4636908&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D4636908
BPW34 Commercial p-i-n Diodes for High-Level 1-MeV Neutron Equivalent Fluence Monitoring
Abstract NEUTRON AND GAMMA DETECTOR PIN DIODE BPW34
The BPW34 p-i-n diode was characterized at CERN in view of its utilization as radiation monitor at the LHC to cover the broad 1-MeV neutron equivalent fluence (Phieq) range expected for the LHC machine and experiments during operation. Electrical measurements for both forward and reverse bias were used to characterize the device and to understand its behavior under irradiation. When the device is powered forward, a sensitivity to fast hadrons for Phieq > 2 times1012 cm-2 has been observed. With increasing particle fluences the forward I- V characteristics of the diode shifts towards higher voltages. At Phieq > 3times1013 cm-2, the forward characteristic starts to bend back assuming a thyristor-like behavior. An explanation for this phenomenon is given in this article. Finally, detailed radiation-response curves for the forward bias-operation and annealing studies of the diode's forward voltage are presented for proton, neutron and gamma irradiation.
BPW34 DATASHEET
http://www.vishay.com/docs/81521/bpw34.pdf
