Grumage
Quote from: guruji on May 02, 2013, 03:31:35 PM
Grum interesting results keep going. Try to move L4 and see if you can hit resonance.
On my setup I made L1 more tight to coils. Atleast neon screwdriver is lighting on L2L3
Hi guruji.
Thanks for the encouragement. My L1 is a real "slip fit" ie really tight. And yes I can find a spot with L4 that gives the best light. But it comes with a greater input current!!
I will carry on experimenting and posting what I find.
Cheers Grum.
Hoppy
Quote from: Grumage on May 02, 2013, 02:28:35 PM
Evening Hoppy,
Just come back from more "mind buggering". Changed L4 for 250 turns on 1.5" former which is tuneable. Now no gain when touching cap cases? ??? Ground 1 @ L3/T2. Ground 2 @ L2 ie where it should be, pulling 5A with brilliant lit bulb.
I still don't get it???
What was the inductance of your T2 ? I get no output on secondary at all. I am using a 240/24 control panel PS transformer.
Cheers Grum.
Addendum.  With scope on input to T2 using X10 probe. Shows 400 V p/p. Disconnect T2, NO light is seen.
Evening Grum,
The 16 turn primary is 84uH. Secondary too high to measure on my LCR. Are you sure you have picked-up the correct HT ground pin as you cannot get a resistance reading on this winding.
Grumage
Quote from: Hoppy on May 02, 2013, 03:52:54 PM
Evening Grum,
Dear Hoppy.
Sorry, I said mind buggered!! Most definitely. I have had my T's crossed :) I meant T1.
Cheers Grum.
To all, previous posts please read T1 not T2.
Hoppy
Quote from: Grumage on May 02, 2013, 04:18:14 PM
Dear Hoppy.
Cheers Grum.
Hi Grum,
Inductance for 240V winding = 4.37H
Inductance for 24V winding = 71mH.
verpies
Quote from: sparks on May 02, 2013, 10:33:05 AM
Can't a photon be blue shifted by matter.
It can be in Anti-Stoke's Scattering.  It maintains thermal equilibrium, though.
And from whence did this energy gain come from?
From heat.
Unfortunately, The opposite happens with Stoke's Scattering.
Is there any chance that electrons have actual orbital momentum a form of inertia which when altered generates photons?
Only if you believe that electrons actually orbit the nucleus like little balls.
