0 Members and 1845 Guests are viewing this topic.
yfree
Quote from: T-1000 on July 15, 2013, 09:24:49 PM
The NMR is same even in the Moon even the approach is different. You can resonate atoms to the level of splitting with electricity and also you can do that mechanically with ultrasound as well. ;) When you understand how it is done there are no limits to material type and approaches..
Actually, NMR is not necessary, for energy extraction. Ultrasound (sound in general) or electricity is necessary.
Nevertheless, ultrasound  can be used to observe NMR. See here:
http://books.google.ca/books/about/Nuclear_Acoustic_Resonance.html?id=izYbAQAAIAAJ&redir_esc=y
elementSix
This Q? is for Verpies..  In a Resonant System like TK where everything from the Resistor to the coil, Capacitor and the input are all in resonance.  When the HV DC Impulse goes into the coil, does this mean that their is very little to no amps being consumed????  Thanks ahead of time for your answer... Sry, Also do you think that using an older style Capacitor Discharge Ignition would be proper for my mechanical replacement of my Impulse Circuit?? I need a range of 10 to 100 Millisecond Impulse waves..
        E6
P.S. Hoppy if your going to go down the TK CONMAN road again, you can at least say the only possible way for all the devices to have been faked.  Not one or two of them, that would be dumb.  The only way he could fake the results are to create a Tesla Resonant Wireless transfer of energy from another spot near by the demo..  He could transfer very large amounts and just tune the coils to that resonant frequency like Tesla did..
zcsaba77
Quote from: yfree on July 15, 2013, 11:10:32 PM
hi yfree
I left a p.message for u.  I'm interested in TK's Two-Disk Motor/Generator.  Can I discuss it with you?
regards zcsaba77
p.s.: thanks verpies  ;)
Hoppy
Quote from: elementSix on July 16, 2013, 12:55:44 AM
I have explained in my post 18155 how I believe TK faked the Aqua2 device (so simple that it will make you laugh). The 'earth' braid is IMO not from stripped co-ax and is most likely a braided nickel-plated copper sleeve sold for screening data cables. This is expensive, so unless TK had a role of this handy, why would he spend out when a length of ordinary multi-strand wire, as used in his previous devices, makes a perfectly acceptable earthing conductor. You may recall TK saying that its possible to disconnect the earth wire. With the grid live and neutral being carried inside the braid, this would be possible, but not at all sensible if carried out in front of investigators!
I've also discussed how I believe the Green Box garden video was faked and again as with the Aqua2 device and indeed the other variants, hidden wire(s) are employed. Even if you are right about the use of Tesla Resonant Wireless transfer, it still makes the devices fake, as powered this way, they could not be self-runners.
HG8AD
zcsaba77 !
Szia Csaba! itt van a Mc Freey analizis fordítása ha érdekel...üdv..:Laci...
