0 Members and 288 Guests are viewing this topic.
Grumage
Quote from: magpwr on August 15, 2013, 04:33:53 AM
Hi Grumage,
Here is the 5min long video base on my Avramenko plug ver 2.0 experiment charging flash capacitor using 1 wire only.
Dear magpwr.
Well done and keep "plugging away" :)
To All.
I took some time yesterday evening and followed the advice given by T-1000. Go to http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg302619/#msg302619
Just have a GOOD read, I was surprised to see how many builders were active then. Also it was good to see that there were quite a few contributors who are still with the thread today, with us newbies, me included in that statement!!
There are a number of points that may help short cut the present series of tests.
Cheers Grum.
magpwr
Quote from: Grumage on August 15, 2013, 08:06:18 AM
Dear magpwr.
To All.
Cheers Grum.
Hi Grumage,
Thanks for the link.I used my own approach by starting from opposite end of caduceus coil away from the input point.
I merely use slightly more than 1m maybe 1.05m for 18AWG(1mm) 5 strands of copper wire.After that i trim excess away to be even.
I then take end to end of the 5 wire together and pull from center to derive the middle of copper wire.I use the middle portion of the 5 strand copper and start from the end of cylinder which i find it easy for me.
This "cold current" or maybe "strong radio wave"  what i'm getting as part of my 2nd experiment mentioned few days back where it lit up Led brightly from secondary coil and another end of led to crocodile lead and left it on the floor.Neon test pen not lit.
This is for T-1000 -May i ask is there a direct relationship between "HV output from transformer" to bulb brightness.
                            If so may i ask if you get -an example -BBQ sparker which uses 1 battery to generate 29KV and connect one of output to the Avramenko plug and another end to Earth.
                            Will this idea work.Reason why i asked this is because i find that maybe high power was used just to generate high HV base on video.This causes efficiency to drop.
I will try out if i got the time to extract the breakdown voltage 3volts across my 10mm white Led since it is already isolated from primary winding and go back into camera HV circuit which consume less than 100mA for 1.5v.
This is just a tiny scale experiment to allow me to understand better in the meantime.
T-1000
Quote from: zcsaba77 on August 15, 2013, 03:06:44 AM
Hi T-1000
If I good understood initial power was (free run) 220 x 0.34 = cca 75W, and if loaded add 220 x 0.014 = cca 3W, you try loaded by more bulb see the effect?
regards zcsaba77
We tried 150W halogen bulb but in the current state of how we took power out if system it was not lit fully.
Quote from: magpwr on August 15, 2013, 08:36:42 AM
In our experiment it was capacitive loop in series to "cold" end of flyback. Attaching ground directly to one of AV plug diodes probably won't give much effect (you can still try it).
Also if you understand Russian language or have someone to translate it for you i just uploaded another old video with theory part for how we got stuff running  - http://www.youtube.com/watch?v=mzYFG8T7InY
Grumage
Quote from: 00 on August 15, 2013, 03:06:48 AM
hello Grum! and all!
non oxydized copper!
00
Dear 00.
NMR or NAR. That is the question.
I see your point....... More clues   ;)  :)  ??
Cheers Grum.
00
Quote from: Grumage on August 15, 2013, 03:00:31 PM
Dear 00.
Cheers Grum.
Hi Grum!
its both Nmr and tesla !
tesla coil is source of ions! and ground is source of ions! + tachyons!(high impedance coil, use litz wire)
electric current=  copper +electrolyte(ions)+ zinc= amps and volts
ferrite+ions+alluminium= electric current.
caduceus or non inductive or  resisitive bifilar coil as modulator 50/60 hz making alternate ns poles
for nmr  material ---------->copper or alluminium is nmr material. split tube or single cylinder. if using single cylinder use ring magnets facing N-> nmr material<- S. else if split copper is used you dont need magnets then. use then only ferrite rings.
ground replenishes or charge the active material ferrite, copper or alluminium
so its a mix of all.
the minute particles ejected are caught in inductive output coil.
00
