0 Members and 99 Guests are viewing this topic.
magpwr
To T-1000 ,Grumage,
My Lithuania Device building status
1)Caduceus  coil with pickup -Completed but  not tested with sweep generator(Pending delivery) to see if there is ringing up waveform on scope.
2)PWM I/C:SG3525A circuit dual putput for driving 2 x 600volt mosfet: SPW47N60C3  -Completed
   Refer to link (http://www.volny.cz/jmartis/flybacks.htm) or I/C specs for tips.Using 15nf capacitor for this experiment.
3)HV flyback transformer modification -Completed.Photo attached.It's hard to spot shop selling HV transformer these days.It will get even harder to buy one in another 10 years time.
  I used around 5 or 6 turns on each winding using 18AWG .The holding pin on ferrite is removed for good since i noticed ferrite core was already glued to transformer as well.
First test with hv transformer used spark from hot side to derive the ground pin on transformer(shortcut method).Takes around 1 minute to find out.
After tuning to a sweet spot(frequency) and at a reduced pulse width.I was able to get spark flying across 3mm or 4mm gap using as low as 3.6watt...4watt as verified using
"Turnigy 130A Watt Meter" powered by a 12volt Lead-acid battery.Increasing pulse width to 50%(max) the current consumption rise to over 60watt at around 5.1Amp X 12volt.
I'm attempting this PWM approach since it gives me more control compared to "Royer oscillator".
Once i have obtained  the High KV diode ,Caps and adjustable spark gap with enclosed window.I would able to report any findings of interest.(OU Sweets hopefully) :D
Zeitmaschine
Quote from: Grumage on August 17, 2013, 11:06:08 AM
Dear Zeitmaschine.
This is my interpretation of your recent post's. Please advise any direction that you see fit.
https://www.youtube.com/watch?v=yHkqn2cG-no
Cheers Grum.
3.5 amps ground current? Can't remember having seen this much ground current anywhere before (except TK of course). :) :)
Now I would modify the alligator clamp. Simply wrap the ground wire conductive around the high amp wire. See what happens.
The transformer noise is the same noise like in TK demonstration, so almost for sure we are on the right track. :D
Quote from: elementSix on August 16, 2013, 06:18:51 PM
Large minds live in large worlds and small minds live in cages...
Free energy for free cages!!
Liberty
Dear Zeitmaschine.
Cheers Grum.
It appears that one would want to limit the power input side, due to the closed loop on the transformer, will tend to smoke the primary without a current limit on input.  It would also seem necessary to extend the 2 coil winding to another transformer so power could be extracted from the circuit in the second transformer at a proper voltage output.
22wInputac     !-------------  output ac (should exceed 22w if it works)
    -----------------------___
                                      =   ground
                                      _
Liberty
magpwr
Quote from: Zeitmaschine on August 17, 2013, 10:40:01 AM
I think the key aspect -or name it the Kapanadze secret- is how the connection between a coil of a transformer and the ground wire is made. It depends heavily on the geometrical structure of the connection point. Hence simply connecting an electric (or an electronic) circuit to ground will not work.
When a rod magnet is moved through a coil it moves the electrons in that coil's wire so there is a voltage generated in this coil (no closed circuit needed). Now replace the rod magnet with a wire as thick as the rod magnet touching the coil. When there is an AC power current going through this wire then this current generates an alternating magnetic field like that one of the back and forth moving rod magnet. According to the Barbosa patent this should capture the electrons from ground so those electrons can amplify the current in the stout wire which generates the magnetic field, thus creating an even stronger magnetic field (»the induced current acts to favor the variation of the magnetic flux«, as the patent expresses it).
This sounds quite logical in physical terms, if it works in the real world then it will sound even better. ::)
A soldering gun works also that way. Maybe such a soldering gun could be easily converted into a free energy device. Who wants to try? :D :P
And just btw, the Barbosa patent does not mention any resonance (between two coils) nor the use of any capacitors. Thus I'm getting the funny feeling that this stuff is another smokescreen put up by TK. >:(
Hi Zeitmaschine,
Part of your quote kinda reminded of me of a magnetic bubble.Around 5 or 6 years ago i know there is this ou device (I'm sorry i can't recall the device name) and this inventor is now dead found in article based on my old memory.
Can anyone assist to recall the name of this ou device-
This was the only OU device using 2 magnet rectangular slab top and below of a caduceus coil(i think around 12cm... 14cm for magnet length base on my memory).This inventor used high voltage charges to capacitor to create a shock to magnet in order to create "bubble within a magnet".I only recalled the inventor mentioned in a site there should be no existing fracture in magnet slab.
Once this magnetic bubble is created in each of the magnet slab.Merely a small amount of power is used to move "magnetic bubble" away from current spot in magnet slab.More like a flip-flop within magnet.
Once power to a coil is removed bubble return to original position and this is what provide ou power.
Many years ago i had downloaded the electronics drawing on how to create bubbles in magnet when my knowledge in electronics was still in it's infancy stage.
Now after changing pc and harddisk few times over the years.I have lost this information and even the name of the device.
Grumage
Quote from: magpwr on August 17, 2013, 12:35:38 PM
Hi Zeitmaschine,
Dear magpwr.
I think you are referring to Floyd Sweet's VTA ?!!
Cheers Grum.
