0 Members and 622 Guests are viewing this topic.
stivep
Quoteauthor=a.king21 link=topic=7679.msg373774#msg373774 date=1381981701]
He's no mug. Just looks like a simple guy but he knows his stuff - obviously.
I'm convinced that there are several people who know the secret
I agree with this part.
QuoteIf TK needs access to any test equipment he doesn't need to buy anything, he just calls a mate. It would be the same if you or me worked as a technician in a university. You get to know people and borrow the best equipment. You don't actually need to own the stuff.
I have problem with this part
Wesley
NickZ
  quote:
  "If TK needs access to any test equipment he doesn't need to buy anything, he just calls a mate".
   I agree with Wesley on that one.
   Or/and, maybe he calls that "mate" to help him build that secret device too?
But, somewhere else...
  Don't you find it very strange that no one has ever seen him work on any of the devices, ever?  I do...  Who could those "others" be, that know the secret???
   Need a detective, yes,  no doubt about it.  Could be that he takes home an already built device, made elsewhere, by someone else. Then brings it home, sets it up again, and later shows it as his own.  I have a very strong feeling that all that wisdom is not coming from TK. And also, as he has nothing more than old junk in his bedroom, and has not mentioned a word concerning having any technical electronics skills, or technical knowledge, as well.
  When 2+2 don't add up to 4...
conico
baroutologos
Quote from: stivep on October 16, 2013, 12:48:48 PMThis is the  message I have  got from one of members of forum...Wesley
  "..I think about Kapanadze... and I think I know how this trick works. It is simple and complicated. Trick is- how to make capacitors with very high density make "full" with High Voltage and "ground". After all, he use ordinary 2 transistor circuit and voltage inverter- nothing more! Its very simple, but tricky! The prove is this video:[/size]https://www.youtube.com/watch?v=j-NLBSBRsBM[/size] It`s absolutely true- he take "spark" when it is needed. OK. Why I think so? Some time ago I listen his Skype conference. He tell about capacitors- he have about 63 000uF cap bank. How to fill them? It is important. I know about long wires- they make inductive "jump" and voltage rise up. I make some "mistakes" with long wires and found this "effect".OK, [/size]Thanks!P.S. That is what I am thinking about :-).
Without implying anything, this guy makes the same observation  as i did and started the thread http://www.overunity.com/13891/large-ground-current-using-single-terminal-oscillator-tesla-said-its-doable/ and supports he achieved the impossible
I do not know if it is even possible at this universe to "fill" via one wire from ground to device using (oscillating current motion) a large cap bank, or in other words a considerably higher capacity that any typical single terminal one in the range of picofarads... but it would be a hell of achievement on its own right since according the classical view this is an IMPOSSIBILITY.
Tesla stated it is possible in his Colorado springs notes July 16, 1899 but again in his July 31, 1899 notes implies just the opposite to be true. Contradicting guidelines at least..
interesting subject though :D
cheappower2012
to a.king21
I buy that Tariel may have access to more equipment,he was trained as an  Architect.
I would say he has a minimum of electronics knowledge,however he is a smart guy,but
complex electronics he would not understand or use,hes creativity is very great,as is hes ability to lie.
I understand that you picked out the  specifications,did you provide the heater.I'm from the US
our heaters are a little different here,this is why I ask.
You said:
It was a pure resistive load with no inductors.
Some heaters have a small fan,its an induction motor,it requires ac to operate,so are
you saying it had no small fan in the heater.
I agree that the heater as a load was the way to go,it generates a lot of heat hard to miss.
I believe you when you said you removed the ground wire and it still worked it indicates that a
ground is not really needed.
I don't buy that the high voltage spark is needed at all only to imply its a Tesla invention
to fool people so they focus on Tesla.In the end Tariel may have cheated himself,
as the active device is in plain sight
on the aquarium 2 video where normally he hides it.
you said:
The spark gap should tell you that he was using high frequency currents
which was mixed with mains voltage to produce the ou effect.
That is why half his device has static shielding.
I disagree on this,he uses the spark and coils to create an illusion its a Tesla invention
so people focus on Tesla(people think hes a god) not on Tariel.
In one video the green box video,a pulse induced into the coils,that are carrying 220 vac mixed,this caused the clampmeter
not to read the 220vac.There is also an unknown effect related to this particular clampmeter he uses
it creates an illusion of a false ground current,he uses this strange effect to imply that there is a big ground current.
Then you have a ground current,a spark,hv and coils it must be a Tesla invention,its a great illusion.
I have the clampmeter he has,its made by the same company,I posted this experiment a while back
there is no ground current.Because a large ground current with 220 vac and one wire,is impossible,the skeptics,attack this.
There are more impossible things in the aquarium 2 video,you have to look close.
