0 Members and 622 Guests are viewing this topic.
NickZ
  There may also be something blocking our combined abilities to visualize and build such systems. May be no coinsidense, at all.
  If you can visualize it in your mind (like Tesla could), you can build it, but if you can't, then it may only come about and happen by accident. Either way I hope that it's comes about soon, as I see that some of us don't have the patience, that other of us here have shown.
  I however have no choice... I must follow my joy, and the journey is the only way to get there. I'm there already, and so are we all, although we may not know it.
Grumage
Quote from: From other Planet on October 19, 2013, 12:48:15 PM
Im still trying to replicate akulas first device, but now i came to really big problems. Assuming the schematic i attached, is a real one at all.
Dear From other Planet.
To start with there was the original schematic that T=1000 painstakingly drew from watching the video that appeared earlier this year. Suddenly an "Official"?? Schematic appeared!! With what had an apparent mistake this was also rectified by T-1000. This schematic used a pair of IGBT's and was the one I used for my build. The final schematic, the one you attached to this post, was the last,
however at that time T-1000 had been in contact with Roman (Akula) who denied posting any schematics at the time in question!!
I built my device with the little knowledge that was available and a great deal of background from T-1000. We decided to place a capacitive liner within the main coil that was put in parallel with a choke. My first choke consisted of 600 turns of 0.3mm wire and was regularly generating up to 10000 volts at a frequency of around 84Khz. This frequency never altered despite changes to the drive frequency!!
Alas that choke got too hot and collapsed. Others were tried and the last one was made at 250 turns. All were capable of 8 to 10 thousand volts.
As I see it Akula's latest video shows a Current side and the Tesla coil provides the HF HV. I think my device lacked enough HF HV that was supposed to be generated by the internal choke.
I hope the above is of some use to you? And good luck with your replication.
Cheers Grum.
Ganzha
Akulas shematic is equal Tiger's, (Wesley know what about i am talking here).
In both devices is one but big secret. It works with Russian Yoki only,  even more the only old russian  color TV set is good to use!
PS I am very sure that Tiger ask Akula to be his sales manager and Akula is new generation of Tiger 2007!
PPS http://www.energeticforum.com/renewable-energy/9781-tigers-device-0-150-1kwt-replicant.html
x_name41
hello gyulasun, here is my old post in this theme, the difference between his and my scheme comprised the following: my scheme uses amplitude modulation, he does not uses amplitude modulation, my scheme uses single wire transfer of energy, his use wireless transmission, My scheme in the receiving part is not using power switches, he used in the the receiving part power transistors :)
Quote from: FreeEnergyInfo on October 18, 2013, 04:55:03 PM
AKULA0083   SXEMATIC
www.realstrannik.ru/forum/48-temy-freeenergylt-antanasa/129332-ustanovka-akuly-povtorenie.html?start=360#162851
MenofFather
Its about the choke coil, drossel like its called in russian and german. According to the schematic, it has to be 1/4 the wavelenght of the driving frequency or an even multiple of that. Now, for 60kHz, that would be around 1,25 kilometer. First problem: How to measure a 1,25 km wire without buying a special meter, that costs 400-500 euro. Second problem: If u somehow can solve problem number one, u will end up with a coil that has thousands of turns, and so induced voltage in it will be in high kilovolt region. Means it will spark like hell and probably end up burning itself. Not to mention the cap ratings that would be required. Any thoughts on this?
I think, that maybe in first Roman video principe is 50 Hz modelation. То есть 50 герц нужны для подмагничивания, вся фишка в подмагничивании возможно.
