0 Members and 147 Guests are viewing this topic.
baroutologos
Quote from: stupify12 on October 29, 2013, 08:01:17 AM
The only ingredients on the Tesla Transformer you haven't successfully investigated is why all the people who successfully replicated the Kapanadze has a thin sheet/plates of Irons on the Main Coil. A Close Magnetic Circuit composed of Iron Wires Close Circuit and Iron Plates Close loop also.?
Look for the Iron Plates or Iron Wires configure in a Close Magnetic Circuit. That is the real secret here to produce a induced voltage on the Secondary with a Phase Shift 90degrees. The Close Magnetic Circuit is the reason of the lag or delay of the Phase Shift.
Meow ;D ;D
You are referring clearly to Tesla's US patent 433,702. Interestingly, i have never seen any experiment on this ground. Most of people like to play with sparks.. i love sparks too. Maybe Grum or other guys with Yoke device, can take their time and wind:
yoke + secondary. On tops of this, iron soft wire, isolated (eddy currents exclusion), closely spaced so as to form a superficial thin core, and on top of that the primary wire. It looks like fun.
Shokac
Quote from: a.king21 on October 29, 2013, 12:59:19 PM
I did a lot of experiments on the Barbosa-Leal  patent and got nowhere. Then recently it dawned on me - Tesla told us a long time ago.
We need HIGH FREQUENCY and/or HIGH VOLTAGE, to get anything out of the earth. It is that simple.
Otherwise the earth absorbs the energy and turns it into.....HEAT!
So redo the Barbosa stuff with high voltage and or high frequency.
You are not alone!
I have tried in various ways, but nothing.
I read from patent very interesting staf! Captor work with AC and DC.....?!?!?!
Where is the catch????
Patent:
....."Wire 3 can have an alternating voltage applied to it in order to get alternating current in wire 4, but please understand that the current flowing in wire 4 is not the result of the current in wire 3.  If the current in wire 3 is DC, then the current in wire 4 will be DC as this is not a conventional transformer, but instead, it is an electron trap, operating in an entirely different way."
captainkt
@Shokac, If the DC is pulsed into transformer square wave then AC comes out of other side, this is fairly common Knowledge.
Keith
captainkt
@all, watching the single wire Russian transmission, the bulbs light up with a slight yellow/orange colour and slowly come up to brightness just as Kapanadze or Dinamo or Daly bulbs do. Certainly in a different way to grid mains being used. Hoppy take note.
Keith
Shokac
Quote from: captainkt on October 30, 2013, 04:21:38 AM
Keith
yes, but only in push-pull configuration.
