0 Members and 469 Guests are viewing this topic.
v8karlo
Year ago I observed this on low voltage capacitance transformer coil.
But funny thing was when there was no load (short circuit) it was showing
huge amperage but with any kind of load at the output it disappear and
we concluded there was no overunity.
Then I didnt understand that the difference in voltage in C1 and C2 is
essential there and I was using only 10V input.
After that I switched to HV and understand why it happens.
If you use lower voltage and switch it with transistors you must
add more capacitance to C2 bank and at the output must be output
transistor which opens and close sync with input transistor.
When first is open second is closed with no overlapping time.
You can not use output just like that, you must sync it with input.
The C2 has another role on primary coil.
So the answer is yes, without any problem, just use fast switching mosfets
on capacitance transformer coil (caduceus and bifilar).
v8karlo
The best results I observed when C2 is not empty.
In C2 bank must always be some voltage.
It must not be empty!
Just play with it and enjoy.
v8karlo
And if you wanna play with lower voltage you can
play with this. It works at any voltage and you
dont need any coils at all. just two transistors
sync one to other, no overlaping time.
It even works in simulator because it works
on existing principles which are well known.
Using only 2 plates of capacitors bank you energize
all the plates in between, then you cutoff source
and use energy from all plates together.
I think its simple enough.
Once more the principle is using primary current
along with induced current together at the
output, so there must be more energy at
output then on the input, thats all.
And maybe you can use this circuit instead of C2
in the first method (combine them) ... just thinking,
never tried.
gyulasun
Hi Karlo,
Many thanks for all the hints on your circuits.  Regarding your rar file I can see it is an  .ms12 file but I do not have the simulator to open it,  could you make a picture or pdf file from it?
Greetings,  Gyula
v8karlo
I made a mistake in the first schematic.
Input is direct current pulses.
