0 Members and 75 Guests are viewing this topic.
Zeitmaschine
Let's assume for a moment that this flashlight is not fake but the real thing then there are some striking similarities when we compare the schematics of the flashlight and the Kapanadze patent with one another.
The lower coil in the flashlight schematic (right) is pulsed by the MC34063. The upper coil apparently creates a back EMF due to that pulsing and charges a capacitor with the generated current (to keep the circuit running). If that energy is indeed additional energy (coming from somewhere) then the upper coil of the Kapanadze schematic should also create additional energy when the lower coil is pulsed by a frequency generator (as mentioned in the patent). If that upper coil in the Kapanadze patent is connected somehow to a 220V/50Hz resonant circuit, then what will happen with that additional energy created by the upper coil?
The transistor (marked green) switches the 100µF capacitor between charge mode (when the negative back EMF arrives at the inverter stage pin 13) and discharge mode (powering the circuit). The other five inverters in the CD4069 (marked blue) are not important. They only drive the two flashing red LED's as an eye candy.
Just a quick thought. :D
Hoppy
Quote from: verpies on January 21, 2014, 08:29:57 AM
Thank you for your work in helping Russian non-speakers to understand this video.
@Hoppy
Don't you just love the rubber hose test for a hidden X-wire ?
@ Verpies,
I can't understand this guy. First he lines the lamps up along a carpet edge, then in the next video mounts the lamps on a broomstick but doesn't show us the top of the stick where the 'X'-wire probably meets the stick. Then in this latest video he uses that rubber hose to convince us that there are no hidden wires, whilst assuming that we are silly enough not to notice that there a large cavity under the plastic sheet for a high capacity flat pack battery! He really needs to up his game, or better still give up. He can't be serious and is probably just after max hits.
http://www.youtube.com/watch?v=ljKX9Om7Z4s
http://www.youtube.com/watch?v=-poc9JSHoWA
Those tiny wires can be hard to see, but they can supply all the power you need to make your demonstrations convincing.
Hoppy
Quote from: TinselKoala on January 21, 2014, 12:06:38 PM
This is the trick I think Kapanadze used on the Aqua2 device. A thin insulated 'hot' wire running through the tubular earth braid.
forest
Quote from: Hoppy on January 21, 2014, 12:27:32 PM
Yes, maybe.... however that would be real magic to keep 2kW for few hours via tiny wire ;)
