0 Members and 138 Guests are viewing this topic.
From other Planet
@a.king u should go see kurts videos on youtube he is very engaged in this TMT stuff
http://www.youtube.com/user/kdkinen/videos
jbignes5
Quote from: a.king21 on January 24, 2014, 02:17:22 PM
Yes and no. The Tesla resonance I am referring to is the Magnifying transmitter free coil as per colorado springs.
Of course Tesla knew about tuning because he invented it. But tuning was also to individualize the receiver.
Tuning was also to grab harmonics, but the main one was the free coil which self resonated like a bell. If the bell was tuned to middle C it didn't matter how many times you hit it. It was always middle C.
I won't bore you with too many details but get a copy of the book Cold War Secrets.
" The most efficient Tesla Transformations were obtained only when the disruptive radiating wire line equaled the mass of the helical coil."
"  Tesla transformers are not magnetoelectric devices, they use radiant shockwaves and produce pure voltage without current. No University High Frequency coil must ever be called a "Tesla Coil", since the devices usually employed in demonstrations halls are the direct result of apparatus perfected by Sir Oliver Lodge and not by Nikola Tesla. The Tesla transformer is an impulse apparatus and can not be as easily constructed except by strict conformity with parameters which Tesla enunciated. Tesla transformers produce extraordinary white impulse discharges of extreme length and pressure, which exceed the alternating violet spark displays of lodge coils."
" While looking and seeming the same, each systems actually performs very different functions. Lodge coils are alternators. Tesla Transformers are unidirectional impulsers."
these are some of the gems in the book...
I am of the opinion that there are many thinking they have a true Tesla system. I highly doubt that claim in most situations. There are many that detract from the Tesla discovery by not showing the difference between the two systems. In fact most don't want you to have this and will quickly derail the conversation back to the known fallacy  that they are using Tesla technology(lodge coils).
Might I ask a few quick questions?
What happens when you impulse a bifilar pancake coil? Since the self induction is canceled by the capacitance what happens to the impulse?
What happens if you use the conical form of the bifilar coil? Would it concentrate the flow around the coil?
a.king21
Zeitmaschine:  This is right up your street: http://worldwide.espacenet.com/publicationDetails/description?CC=GB&NR=2432463A&KC=A&FT=D&ND=&date=20070523&DB=&locale=en_EP
It's Harold Aspden's double 3 plate capacitor free energy system.  Maybe it's the Kapanadze secret.
Jbignes5: Don't know about conical, but the bifilar becomes a capacitor and stores the energy.
penno64
Farmhand
Three coil Tesla Transformer/Transmitter/receiver. 760 Khz  Power factor of the coil is over 0.95.  ;)
Light lighting test. Lower power running
http://www.youtube.com/watch?v=6Y1U1PSmAjQ
Spark run for fun. Higher power running. Still only a few hundred Watts.
http://www.youtube.com/watch?v=1nkJtrKCdFg
Test with smaller mirror coil, showing a higher voltage from the unpowered mirror coil.
http://www.youtube.com/watch?v=1rG_Rfqv6O0
Transformer. Picture attached
Circuit attached, notice no Terry filter, no big resistors to waste power. I do have regular line filters and the power meter behind those works just fine. No glitching, which is handy.
Under certain conditions it will produce double helix sparks. Attached.
Last I saw Mr Clean was doing some nice work on a similar arrangement. Not sure how far he went, maybe it's time I check, might be fun to see what he's done.
