0 Members and 72 Guests are viewing this topic.
FreeEnergyInfo
VIDEO ...
www.youtube.com/watch?v=Gs2hPw8hf1M#t=39
FORUM ...
www.realstrannik.ru/forum/48-temy-freeenergylt-antanasa/134719-ruslan-sergeevich-opyty.html#189301
verpies
Quote from: Jack Noskills on January 31, 2014, 02:04:49 AM
Can you also explain why my watt meter in front of audio amp does not notice anything when I connect load ? It should be able to show 10 watt change even it is not very good meter.
Mostly because your amp draws the same or similar power from its power supply regardless of the load placed at its output.
Such circuits behavior is very common.
For example see an ubiquitous power supply circuit below (not an amplifier).
In this circuit the input power is relatively constant regardless of the load.  Really!
When no load is connected, a lot of power is dissipated in the internal 1Ω resistor due to current flowing through the Zener diode.  When a load is connected to the output, part of the current shifts away from the Zener diode and into the load, ...but the sum of these currents flowing through the internal resistor, remains the same.
Similar mechanisms occur in class A and class AB amplifiers (especially at light loads).
Utopia Now
LC Circuit with 2 coils    ...  very interesting  :  YouTube  Energy Propagation   http://www.youtube.com/watch?v=kQdcwDCBoNY
DilJalaay
Quote from: Utopia Now on January 31, 2014, 03:59:02 AM
Dear Utopia Now,
yes good demo.
still current flow in primary through bulb, but the bulb not lit.
its not mean that no primary current, as it already discuss by verpies.
its all about power transfer theorem.
take care.
bye
Jack Noskills
What would be the correct way to measure, amp meter in place of bulb ?
In my test input halogen was cold and output was hot.
I need to do some tests using step up transformer. Normally it cannot put a light to 40 watt bulb even 5 watt halogen is hot and shining bright. If tuned system can light the 40 watt bulb without any heat or light in 5 watt halogen then it is a sign on what ?
