0 Members and 168 Guests are viewing this topic.
stupify12
I will only laugh to people like you. :P :P :P
I have already achieved the sole working device from the Working Principle of Nikola Tesla. Tesla always mention and have given a detailed construction on his device which actually works.
The device when loaded with so many LOAD will only boost its performance. The Magnetic Field of the Primary Transformer is away from the Magnetic Opposing Field of the Loading Transformer. When the other wound Loading/Secondary Coils are closed circuit/shorted will only make the device function beyond optimum efficiency.
@Farmhand everything you say is correct. Also everything Tesla said is also correct. But may I ask you did you observe at hand those phenomenon and peculiarity which Tesla said/showed on his writings?
I am very happy that I could do what does Tesla showed to the people on his time. Everything Tesla said is correct and actually works. I think this is the only suggestion I could give to everyone, try to backtracked which work is the original and easier to do=Nikola Tesla.
quote author=Farmhand link=topic=7679.msg391422#msg391422 date=1394156236]
Well I would say that Tesla himself stated his magnifying transmitter was less than 100% efficient. So these arguments are baseless. And an insult to Tesla.
Just past figure 82. Clearly stating it would take 100 Horse Power just to idle the plant with no output, and just as clearly states that if energy is taken out of the system then the input will increase. And he is not counting the losses from the input generator or the resistance losses in the copper. So the actual losses are more as he also clearly states.
Info source.
http://www.tfcbooks.com/tesla/nt_on_ac.htm
Tesla Quote.
Power is not energy. If energy is taken out of the system more power needs to be applied to transfer the energy, as per Tesla's own words. Accept it or not, not my problem.
I can take a toroid transformer wound Tesla converter style, with the thin wire coils having a large inductance and with it just sitting on the bench without even a ground connection I can get 1.3 volts from it at 50 Hz, induced by the grid power in the room. If I ground one end I guess the amplitude of the wave form will increase quite a bit. this is without any tuning as well.
[/quote]
forest
Quote from: stupify12 on March 14, 2014, 01:17:33 PM
Info source.
Tesla Quote.
May I ask : do you use mechanical or electronic switching device ?  I have left with 3 costly mosfets and hate to burn them so I posponed starting my device and it's almost  a month now while I'm thinking what else I can do to protect them.
I have a couple questions for experienced electronic gurus  but the first one is simple:
How long do mosfets run in most demanding applications like induction heating when properly protected by snubbers , transils and so on ? Is that a year , 2 years, 5 years ? Does somebody have any report on statistical research on this issue ?
Grumage
Quote from: forest on March 14, 2014, 01:52:43 PM
Dear forest.
Your question started me thinking !! Perhaps the answer lies in finding out what the output transistors are in a Solar PV inverter !! After all they run for really long periods on a day by day basis.
Useful ??
Cheers Grum.
stupify12
On low voltage side, I used transistors with a capacitor(HV like 1600v from a TV) + neon parallel to protect the transistors from the spark gap destructive discharge. In that way the transistor doesn't even sensed that there is a Electrostatic discharge on the circuit. The HV Cap is parallel to Collector and Emitter terminal, I usually used some HV diode as protection before but it will only destroy the transistor at a later time because it will eventually short out.
I only used simple 1 transistor joule thief look-like fly-back driver for now. The heating problem for a transistor would be from a lil bit few turns of the primary oscillator coils. Other would be transistor BASE voltage, and transistor voltage between Collector and Emitter.
The protection diode and neon cant handle the spark gap discharge circuit, it will always fried your transistor.  ;D ;D ;D ;D
The next thing that I will create will be device that will not need spark gap anymore, but still it will be a solid state with timely governor.
Meow ;D ;D ;D
lost_bro
Quote from: Grumage on March 14, 2014, 02:34:20 PM
Dear forest.
Useful ??
Cheers Grum.
Hello Grum
I have that Answer for you:
CREE SiC MOSFETs
Fully Avalanche rated and one tough son of a gun.....
1200volts.....
This is precisely what the Chinese used last year in their Don Smith Tang replication.... now removed from the internet.
They are  a bit expensive at $16.00 to $30.00 USD each.
take care , peace
lost_bro
EDIT  the PDF for the specs of the SiCMOSFET is hidden between two of the photo:
and this device does NOT use a SG, it is Solid State switching utilizing SiC MOSFETs from CREE
