0 Members and 139 Guests are viewing this topic.
lost_bro
Quote from: Grumage on March 14, 2014, 02:34:20 PM
Dear forest.
Your question started me thinking !! Perhaps the answer lies in finding out what the output transistors are in a Solar PV inverter !! After all they run for really long periods on a day by day basis.
Useful ??
Cheers Grum.
Will attach again both PDFs , the older style 1st generation SiC MOSFET and the NEWER 2nd Gen SiCMOSFET from CREE.
take care, peace
lost_bro
elementSix
Quote from: From other Planet on March 13, 2014, 12:01:08 AM
@elementSix:
So u claim, this high activity, how tesla calls it, is the requirement to drive his OU devices correctly? U can show a schematic of the part of the circuit into which the capacitor is discharged?
The discharge goes right into the primary.   The tuning of a working system requires strict rules that must be followed in order to get the increased output.  Use of adjustable inductance, resistance and capacitance.  Tesla has a patent on a tuning device.  He used a Rheostat and adjustable self-induction coil that he moves a metal rod in and out of to adjust the impressed upon vibrations.  Variable capacitor is nice, but is not good for HV DC.  Tesla used a two plate adjustable capacitor to tune his impulse generators.  Both plates had boiled out oil as the dielectric and a bolt connected to each plate and moved them close or farther apart to fine tune the resonant circuits.  Current Resonance is also a main part of tuning the generator.  Once all circuits are in resonance, you must adjust the voltage input to the current resonance.  The lower you can get the amp's. in the input, the better.  The voltage is the source of the magnifying output energy.  That's why High Voltage helps the output.  Unidirectional currents are also a must part of getting more out than in.  The input energy into the primary discharge circuit must go in one direction.  HV diodes are obviously a part of the primary circuit.  Ill post more in a bit, just got home and need to sleep.
This is the Tesla Patent for fine tuning.
http://www.teslauniverse.com/nikola-tesla-patents-568,178-regulating-high-frequency-currents
This is his patent for capacitors that work best in his system of High Frequency Current.
http://www.teslauniverse.com/nikola-tesla-patents-464,667-electrical-condenser
Here is a video on Teslas damped and undamped waves.
http://www.youtube.com/watch?v=sRqATZwPhp8
andrea76
Quote from: lost_bro on March 14, 2014, 02:55:18 PM
Hello Grum
I have that Answer for you:
CREE SiC MOSFETs
Fully Avalanche rated and one tough son of a gun.....
1200volts.....
This is precisely what the Chinese used last year in their Don Smith Tang replication.... now removed from the internet.
They are  a bit expensive at $16.00 to $30.00 USD each.
take care , peace
lost_bro
EDIT  the PDF for the specs of the SiCMOSFET is hidden between two of the photo:
and this device does NOT use a SG, it is Solid State switching utilizing SiC MOSFETs from CREE
this is the link:
https://www.youtube.com/watch?v=vowN5BFGW1c
MenofFather
From other Planet
Quote from: elementSix on March 15, 2014, 01:24:42 AM
ui, im i impressed.  :o Saved ur post on my HD i will follow ur advice when i get back to my don smith builds. I have a feeling that will make it work ...  ;) :D ;D But, like the chinese i plan to use high voltage MOSFETS next time im really fed up with mechanical switches like spark gaps, surge arresters and relays. Those almost all stick/change behaviour within minutes, at least mines.
Kind regards,
From other Planet
