0 Members and 38 Guests are viewing this topic.
magpwr
hi everyone,
I have attached photos containing 3 fake HV 100ns  10KV,25KV,40KV diodes that can't support frequency higher than 100HZ.Verified using signal generator.
These diodes are all purchased from ebay Please avoid these diodes at all cost.
I had my suspicion on the diodes in the past until i built a Don Smith device i have confirmed these diodes are not designed to operate at high frequency.
I have waste over 100USD on these diodes.Imagine 1 40KV diode cost around 22USD
Hi Grumage,
I have some success with Don smith device late yesterday night which i am able to light 5watt and 60watt 220volt bulb at around 110volts from the Don smith secondary coil.
Tuning the Don smith device was a real pain but once the 5 turn primary winding is positioned nicely in the pvc pipe and the duty cycle can be made very low 10% ...18% at 55KHZ and consume around 2Amps from 12volt battery.
I'm able to see trumpet waveform which increase in amplitude.
Primary coil  5 turns of 8AWG copper, 3uH <0.2 Ohms is connected in parallel with 0.3uf caps.My plan was to get around 205KZ
Using somewhat similar setup as the China Don Smith replication device which was using a B&W coil 2414 or 2404 in "CW direction" for both winding.
For some strange reason i'm able to get power only from one secondary coil.Trying to place primary coil exactly in the center don't produce high voltage output.
The primary coil\0.3uf caps  is powered by 600volt mosfet.First using 12volt battery as supply and improved light output by using a 10amp step up boost converter to convert 12volt battery to around 60volts under load 2amp at around 10% duty cycle.
Tuning caps used 0.1uf 4000v x 2 in series.For the time being i'm using <30ns 600volt diode for the Don smith device.
I have just destroyed 2 of my PWM signal generator in 24 hours is a cheapskate sig generator UDB1000 (Shorted Gate and Drain at mosfet killed the output stage)and another SG3525AN PWM IC (Connected to 60volt supply from boost converter and killed it.Max supported voltage is mere 35volt).
I can't show any demo of my Don Smith for time being without any functioning sig generator.
In the meantime i will need to get 50pcs of <30ns 600volt DIODE to form HV diode so that i'm able to connect to NST 10KV,30mA.
These diodes will also be used for Kacher tesla coil experiment as well.
http://www.youtube.com/watch?v=JECf2SJAwQ0
The replication of my Don smith device is considered a success since i am already able to light 60watt bulb at 12v or  60volts supply,once i get resonance.
5uf caps in parallel with bulb.
Do take note Don smith device was suppose to be powered by high voltage around 1KV onwards..
The advantage in powering don smith device at high voltage is the duty cycle can be kept low 10% <20% and the amp draw from battery can be reduced.
I may create a another set of Don smith secondary winding which would be CW&CCW instead of CW only.
MenofFather
 magpwr, interesting post, but I not understand that is input voltage and curent and output is 60 W bulb? on that brightnes it work?
starcruiser
@magpwr,
Those numbers seem to indicate under unity to me, congrats on getting it to work though. I figure for a 60watt 120vac bulb would consume roughly 500ma right? and even less for a 220v type. Have you tried to tighten the coil on the secondary, you pix looks like they are space a bit far apart in the middle. this might improve performance for you.
Regards,
Carl
magpwr
Quote from: starcruiser on April 06, 2014, 03:05:47 PM
@magpwr,
hi starcruiser,
The first successful experiment revealed that once i get resonance after positioning primary coil then i raise voltage to 60volt to drive primary coil.The input voltage to primary is suppose to be much higher than that in KVolts.I started with low voltage since i thought if i can't get any output after getting into resonance ,i would then have to run away from don smith device for good.
For don smith device there are 3 factor or ways to get maximum voltage output
1)Position the primary coil to get so call maximum voltage output
2)stick with 34% duty cycle which ensure mosfet don't get blown due to high current.Then lower duty cycle to 20% or lowest 10% once the device is tuned for maximum output.
3)I noticed there are around 3 or 4 frequency setting in khz in order to get useful voltage from don smith device.Pick the frequency which give the highest voltage since there is a another one which nearly produce the same output voltage.But the duty cycle isn't as low as 10%
.I will talk about this later.
optional-
4)Only for those whom have spectrum analyzer since i don't have one.It will save time by revealing the peak frequency since there are around 3 or 4 to pick base on my experiment.
Lastly i would like to mention once the don smith is tuned for maximum output.I would only need duty cycle as low as 10%  although around 18% is better in order to maintain high output voltage to light a bulb.
Imagine this i'm merely giving 10% push to maintain similar speed.In this case it's about maintaining high voltage even at as low as 10% duty cycle at 55khz.Any lower the output would just drop by around 20volts.
But for starters it's best to stick around 20% since it's a pain to tune the device base on the 3 factors which i mentioned.
I merely need  10% duty cycle to maintain a high voltage of around 100volt
Imagine this i use around 30watt of power from battery to power 2 bulbs one 5( watt and another 60watt 22volts rating)at around 100volts .
There is a huge noticable improvement when i raise the primary voltage from 12v to 60volt via boost converter.The duty cycle can be kept low in my case 10% <18%.
Take note this device is suppose to be powered from much higher voltage this is where i am headed.For safety i started with low input voltage just to see if this device was fake.
My plan is to go for higher frequency around 220khz like mentioned in pkjbook page 260 then from there linked to chinese forum which i translate it to English.
All experiment on hold for now since i do not have a working signal generator.This gonna kill time once more.
NickZ
   Guys:
   Nice tests, and device Magpwr.  You do some clean work... Good luck!
   Igor Moros has been working hard towards "energy recuperation", in his latest video.  He's showing how by using ferrite toroid cores, and induced coil shorting and such, a portion of the input energy is sent back to the battery.
I guess that he got his order of caps, and stuff.
  Check out his last video.
  https://www.youtube.com/watch?v=dFGTQ06yeEw
  For those of us that like to play around with high voltage coils, Exciters, and carbon/aluminum galvanic cells... you might find some of my older videos of interest. These videos (below) were made a couple of years ago, but are still maybe worth watching, especially if you haven't seen them.
  Here:
  https://www.youtube.com/user/NickZ530/videos
