0 Members and 140 Guests are viewing this topic.
elementSix
Quote from: elementSix on April 13, 2014, 09:11:37 PM
Do you guys have any comment on these circuits.  Also i asked in the akula thread, just for thoughts.  Is the area pointed out for the primary..
Could those relays be replaced with a transistor??  Or is this a waste of time..
DilJalaay
Quote from: elementSix on April 16, 2014, 08:26:52 PM
Yes search Solid state tesla coil (SST) you will find..
Relays are good for low frequency less then 1000.. with low current and voltage ratings.
Regs,
D.J
captainkt
@elementSix, Hi nice to hear your remarks, I do agree with you. All I need to know is the very basic principle to follow I have been bounced from one idea to the other on this thread and in the end get no where . I build stuff every spare moment including a rotary switch that might be like yours, copper strips in resin rotor with variable speed motor.
Things that baffle me are charging of caps AC or DC and does this mean that Tesla used DC in his circuits as most Patents appear AC with caps?
Regards Keith
  PS. my experiments using solid state have cost me dearly with inverters power supplies and meters etc destroyed constantly. Just bought proffesional power supply from USA and it lasted 2 minutes replaced major components and it lasted another 2 mins just pulsing a coil. Promising results for 2 mins then start again over.
alejandroguille
Quote from: elementSix on April 16, 2014, 08:23:47 PM
I presume you have not read this forum for long?  I posted exactly how it works.  The only reason I am still posting circuits that might be possible controlling devices is because I use a cam with contacts for creating the impulse train that creates the static type of potential. As it was just pointed out with the relay contact, they burn up and mine are brass and suck for long use.  But I suck with circuits, I am more of a builder than an E.E..  I had help building the TK energy conversion device, but that help has taken off and I have had shit for help from those who post on here.  Yes, I know that most who post here are Feds.  But if some one else would at least try to make a little effort to create this conversion device it would help me out and maybe some one with the Circuit building know how can help us make the "Resonator".  Which is just a PWM that varies the transistor driven by the square waves pulse width and frequency that creates the Impulse.  EFNMR has been found that it can now be created by just using pulsed DC.  Now the Earth provides the low strength homogenous Magnetic field and the impulse turns the nucli up from the low energy state and in doing so, releases energy.  But there is a relaxation time that is required which is needed for the Nucli to return to its natural position with the Earths Field.  It is a very short time and it's called the T1 or T2 relaxation time.  This also varies with the metal that is being used.  When they used HF AC to spin the Nucli, the larger the magnetic field used, the higher the frequency that is needed to spin up the Nucli.  So this is why the Impulse timing, resistance, capacitance and also as equally important is the input voltage and current.  It too must find its resonant point within the circuit.  The wave length of the Impulse can be change the output.  Shorter waves are best, and I am pretty sure that it must be a damped wave.  I try to tell you guys everything I know, but I am not an expert.  VisaVe, why I need help.  I hope you can figure it out.  I am not on here much anymore.  But will drop in and post when I can.  Good Luck..
Hello, thank you very much for telling me everything.
I have read most of this forum and I never read the word "It works!"
I will write down what you say, and take it as a guide.
Thank you very much!
a.king21
I missed your circuit and your description of how the device works. Is it possible you can point me to the relevant post or posts? Your information would be greatly appreciated.
