0 Members and 169 Guests are viewing this topic.
boybolangana
kapanadze is an old man right? before cellular tech, people communicate by radio.HAM,80 M, 100 M, etc.maybe a long a go he active as one of radio member?. we  can listen frequency as sound with radio.kapa dont have oscilloscope,so how he tune his freq device?RADIO! .too simple? tried!
on receiver/transmitter there is xtal cap or variabel condenser.
yes we can tuning/change freq by using variable condenser or change xtal.
on receiver/transmitterr there is also VARIABLE COIL,it also can be use to tune freq.
inside a variable coil there is FERRITE CORE.  it's like CHOKING COIL IN TESLA WITH TUNEABLE CORE.
sr193 said the ferro (ferrite) is the secret,akula in one of schematic using  VARIABLE COIL symbol.
starcruiser
So it is ground dependent for electrons When you were unplugging the plug what were you unplugging device wise?
Regards,
Carl
stivep
https://www.youtube.com/watch?v=Knq_jIyWxhY&feature=youtu.be
Some  more of  secrets of Vasmus Free Energy Device part #9.
Free Energy is the energy that is Free of charge but energy must come from somewhere and be converted to usable form of energy
at minute
5:46 please note that 0.44 A current is clearly showing that voltage must be high  on the tungsten light bulbs.  Total power written in the light-bulbs divided  at 0.44A gives you voltage.
at 5:17 minute Vasmus is increasing  current on the ground wire using  potentiometer.
That clearly states about   push- pull electron pump mechanism with  time  delay.
The inertia of the mass particles  electrons  once activated has its own free flow mass delay.
Once activated electrons flow ( move) from the ground and loosely coupled     coil of load winding ( big coil) is dissipating that energy at "pull' interaction not allowing mass to stop as next demand for electrons flow is just continuation of inertia.
The low frequency carrier is modulated with high frequency picks at very top  of the amplitude presenting as DC of given with.
The amplitude of that square pics is much bigger as low amplitude carrier.
Modulation:
You could picture it as very narrow very high square picks of DC at frequency higher that the carrier.
The rising edge  and falling edge of such impulse is very short however for us the important is that  in the sloping down time there is at certain point the carrier of its very unique time base  amplitude level.
The picks are present only    - from  0 to maximum  of the carrier.
That is very much like Lithuania Experiment.
Wesley
Hoppy
Quote from: stivep on May 18, 2014, 08:19:45 PM
Wesley
Wesley,
A jumble of wires and components is meaningless and IMO a waste of your valuable time trying to explain it all. This guy has already posted a couple of previous videos showing the same unconvincing setups with so called ground wire disappearing into nowhere.
