0 Members and 134 Guests are viewing this topic.
hartiberlin
@romerouk,
many thanks for the upcoming videos.
Please don´t be shine and speak and narrate in the videos.
This way it will get more understandable what you do in the videos.
Many thanks in advance.
Regards, Stefan.
P.S: I will see, if I can get my car ignition coil working in the
next few days and will try to pulse my old big Newman coil
with it and have a few big turn wires in the center,
but I am pretty busy right now, so I can not yet
say, when I will have this done...
Goat
Quote from: bolt on June 13, 2010, 06:14:38 PM
I am not preaching flaws im offering solutions. I already stated that KAPAGEN is a good platform to learn how to tune and system basics towards  OU device. Its already stated yes it works but runs too hot and makes too much noise and EMI so i post solutions for improvements.
You do realize if you run these things for too long you could be wiping out  and if you do that expect the FCC to come round with a SWAT team and kick your ass. You will get a BIG fine and ALL your stuff confiscated. That is why it need refining and the sooner the better.
Why do you need to spend 300 bucks for plans its has been posted here many many times now its a coil thats all.
@ Bolt & All
Good point....From what I've seen of the setups so far it wouldn't hurt if we used a Faraday cage setup and stop all interference to avoid TV and other interference...maybe if we could come up with the dimensions and material to build the Faraday cage so everyone using these setups don't get raided in the process of experimenting....:)
Edit 1:  Just looked at information on the Faraday cage and this looked interesting...posted by Myself248 Aug 28th 2007 at:
http://forums.makezine.com/comments.php?DiscussionID=752
"However you build it, you need to give it a low-impedance path to ground. Otherwise the whole cage is just one plate of a capacitor and will happily re-radiate whatever hits it.(*) Because of the skin effect, fine-stranded braid or wide flat strip is more effective than a solid or coarse-stranded conductor of the same cross-sectional area. RF grounds are their own field of study."
Regards,
Paul
Bruce_TPU
Hello ALL,
According to the Electrical Power Accumulator Patent, 500 KHz is the required frequency to go to ground.  But the HF, at this particular frequency is called the "oscillitory frequency" that allows additional power to be accumulated via the Teluric currents.  500 KHz would be a good output frequency to experiment with....  For those who are involved in actually building something.
Cheers,
Bruce
aether22
Quote from: romerouk on June 13, 2010, 07:13:54 PM
Many of the replicators here are only coming with theories, never tried it  practically .Easy to say do this do that but my way of thinking has almost nothing to do with  these theories.
Don't try to find a logic in what I did, just do it the way I did it. My logic in the most of the projects is different than others. Most of the standard ideas about free energy are already tested many many times before me, what is the point to be part of that many who failed. Testing new ways will bring us the answer in the right direction. 1.6kw load I thing it is  in reality somewhere around 900-1000w.I will make some more videos to make it more clear.I will plug all these bulbs in series connected to the wall socket and see the brightness then I will connect them in the circuit and see the difference.I will also try to take some scope shots as Stefan suggested.
Time is a problem as I have to go to work too, sometimes I am tired and the brain needs to relax. My day to day work is stressing me enough anyway.Also I don't want to destroy my neighbours electrical equipment with the radio waves coming from the coil.I've learned how to diminish the wave a bit now, isolating the spark gap.
In the mean time if anyone is replicating the project please just start 100% with what I have stated here then try to improvise.
I couldn't agree more, this kind on technology does not work in ways convention understands.  The results are not conventional, nor is the operation.
XS-NRG
Yes  Bruce :)
It always amazes me to see how far the BBC world service transmit's on the 648 kHz AM!!! it's insane!!
It makes perfect sense  :)
You just stick a rod into the earth and take some OA94 type of germanium diode with a piezo earphone and bam! there it is...
XS.
