0 Members and 1855 Guests are viewing this topic.
MenofFather
Quote from: zcsaba77 on June 20, 2014, 06:28:40 AM
and what type is the ATX (what was connected after battery), and one another (maybe stupid) question, you mentined ferrite ring, its possible use instead old TV yoke ferrite core? its conical type, I still not saw how its look but I have at home 3 old CRT TV (2 is possible B/W), I havent time disassembly it
"[size=78%]and what type is the ATX"[/size]
[size=78%]Dally use ATX - old power supply for computer. Ruslan use импульсный блок питания 12 volts 5 A- pulses power supply.[/size]
"[size=78%]you mentined ferrite ring, its possible use instead old TV yoke ferrite core?"[/size]
[size=78%]Shore, why not? Basicly you can use any ferite core E core or U core, any. Beause I am shore, that this part not giving overunity, it only needed for standar transformation. [/size]
But if you speak about ferite ring for nanosecond pulses generator, then yoke is not good, it too big, in that case ferite ring must be wery small, about 1 cm diameter, permability it must be 1000, 2000 or 3000u, 3000 is best.
zcsaba77
Quote from: MenofFather on June 20, 2014, 09:14:03 AM
this small ferrite ring is between the transitor KT926 and coax cable, this ferrite core not make OU too, im right?
MenofFather
Quote from: zcsaba77 on June 20, 2014, 03:14:07 PM
Right. :)
br549
Question to anyone who knows. I was having trouble finding the specs. on the K ? 203 Shockley Diodes used in  the pules generator circuit for the RG58 coil, and was wondering if someone would be so kind as to enlighten me as to what the Diode voltage and current were. I Thank you ahead of time, and as always Have a great day.
br549
zcsaba77
Quote from: MenofFather on June 20, 2014, 03:15:17 PM
Right. :)
his/its funtion exacly is keep NMR or ESR, or what? if we want raise output, is important put larger core, or is independent from load?
