0 Members and 96 Guests are viewing this topic.
Meta
From the first page, under a document called Aethertap.asc,
Kapanadze seems to be playing with Telluric earth currents and Orgone generation, commonly called Chi in the far East.
Zeitmaschine
Instead of watching videos without any real outcome make rather some experiments, like the one below.
Effectively this Kapanadze and Stepanov stuff should boil down to connect a (3-phase) transformer in some totally wrong way.
The wronger the better. ;D
Meta
Quote:
Most of his continence and contents of this paper is not critical to the modern science.
Novelty created milestone ...so what?
This paper  only matters when it contradict. Taking your rebellious nature into account,  does not make  this paper a tool to kill  a fly .
Is that clear now?
My questions to you Mr Meta:
-What is that you tried to point  by mentioning that scientific paper?
-Is there anything that your interpretation find to be for use  of OU community?
The purpose of listing the Wittaker paper from 1903 is that Bearden noticed that Maxwells 240 Quaternions were  the result of research similar to that paper. Heaviside excised 236 of Maxwells Quaternions leaving only 4 upon which modern electrodynamic theory is based, to this day. I just wanted to point out the connections. I hope you read more Bearden about this. He surely isnt lying, no matter what his fudged education is,
Meta
Another hint:
If you are not reading a minus sign (-) before your numbers on your measuring instruments
OR,
Your calibrated instrument needle is not moving to the left of zero (0)
Then you are still on This Side and haven't reached the Other Side of reality.
Meta
"Each theory or claim has to be with experiment. Otherwise there is no true value in it."
____________________________________________________________________
True, however I am in a building where I cant do experiments in my room. Too many rules here. This is the reason Im asking one of you to set up my experiment after my diagram of an overunity circuit.....its very, very simple but it should pull as much energy from space as is demanded in any load, because the di pole battery is the collector of spatial potential and is always an open 4D system as long as the BEMF cant get back to the battery to destroy it.
The PDF is 3 pages, called MetaQEG.
The dual coils are counterbary, ie,  specially wound coils that cancel all E, M and BEMF.
It only deals with 4D not 3D.
4D is where gravity is at 90 degrees to both E and M.
From these axially aligned dual coils is a gravity beam coming out the axis like the axle of a bicycle wheel or like the plasma jets of a galaxy.
The circuit utilizes the Hole Theory and negative electrons moving from negative to positive.
The fast switch is at the relaxation time of the electron which is between 5-30 nano seconds. Every time the electron relaxes, it pushes virtual electron potential into the load, before the electrons can become hot and visible.
