0 Members and 144 Guests are viewing this topic.
NickZ
   More and more theory.  But, not a single working device.
   I run my Earth ground line (37.5 meters) into my well.  Nothing unusual to report, that I've found by doing so.
   Your link does not work Wesley.
stivep
Quote from: NickZ on July 03, 2016, 09:47:38 AM
How much deep ground copper pipe and how much pipe or wire i use
stivep1
ground is the ground, The Ground Wire.
The term "ground" refers to a connection to the earth,
which acts as a reservoir of charge.
A ground wire provides a conducting path to the
earth which is independent of the normal current-carrying path in an electrical appliance.
Quote+stivep1 may i dig ground Approximately 80 feet into water level And put ground wire in this hole
stivep1
interesting question. Please check telluric current:
  http://www.ancient-wisdom.com/earthenergy.htm
Please note that  you need  to get right amount of self-education
in this area just to be able to
understand say- proper ground  and  its properties.
In  the simple  language  - you do not need to dig ,
but going to Telluric current   can be interesting .
The  typical ground is good 6ft long
copper rod  pushed into the ground by hammer.
+stivep1 oh your ans too late i dig 2hole north south 65 feet groud into
water lavel and 4mm coper wire at the end 12 mm 3feet long coper rod
sink I spend a lot of mony on this but please tell me how i make this coils
Reply
this is not the question to be directed to me but to Ruslan from  Riga. I can only
relay to my theory of (Wesley's Electrostatic Pump Theory) -google it.
That might be explanation of what is going on in that device.
I simply explain it as electron mass inertia utilized  in process
at which  atractive force is
Electrostatic HV potential ,driven by nano or picosecond generator.
Inertia is present in the dead time intervals between the pulses
Wesley
ground wire can be substituted with artificial ground.
Think of it as balance. metal plate underneath of  ground-plane antenna,
or body of the car for your FM radio antenna , or  your own body for your
portable  radio in your hand. =  balance.= artificial-ground Electrons can
be "sucked" from it as well as from real ground .
Wesley
The difference between some of you guys and me  is that I get pleasure
from hunting science.
I spend  a lot of money on it.
You guys want  the results and quick access to "new big money"
That is why............. I can only be killed,  as  I can not be bribed
nor corrupted.
Yes I can bend,twisted ( temporarily)  but do not  you ever let me
to unbend
I have no gods -some say...All I have is the desire to see frickin
monopoly go down.
Wesley
ramset
Thanks Grandma
a.king21
Eric Trump, Donald Trump's son just said in a Fox interview " We can make a car that runs on water"
