Ecotestgroup
Ecotest is a worldwide distributor of radiation detection technologies and offers a great selection of radiation detectors that will suit every need. Visit us to order radiation equipment. https://ecotestgroup.com/
darediamond
Thank you for sharing this DEEPLY VITAL INFO!
I recently develope full interest in Tariels Gen when I finally confirmed  that for transformers installed in my local area to work, it must receive ground connection which serves as Negative while the Air which provides the Voltage electrons is the positive.
Don' Smith of blessed  memory also revealed the same liberational secret in His famous book resonance energy methods. He said the power from the electric company does not really comes from the dynamo nor transformers be it set up or step-down. He said everything comes from Air and THAT POTENTIAL OR POSITIVE ELECTRONS CAN BE GENERATED BY INDIVIDUALS TOO!
So Tariel now complets the sentence by is Gen. And that Is that : ALL. YOU NEED TO DO ALTER WARDS IS TO TAP YOUR NEGATIVE TOO FROM THE GROUND!!
Now I can liberate  my fellow Nigerians with this knowledge.
cliff33
Hi Darediamond,
Some time back I think it was you who said that to get maximum magnetic strength from a solenoid coil, it should
be wound trifilar or more and than connect these wires in series.
Sounds reasonable, but I just wanted to ask you if you yourself have tried it or is it just  theory
you read about?
NRamaswami
Hi Cliff33
What Darediamond has said is correct. A better thing is to put plastic sheet, iron sheet or iron rods, plastic sheet between each layer of such wires to produce great magnetic field at the lowest input. I have done it myself and I have even a coil wound like that with me ready. But the coil draws enormous current if we do not connect all the wires in series and if one or two of them are kept open. I have tested two different 10 filar coils. Both would magnetise at the lowest input. But if we make one wire an open coil and connect 9 others coil draws enormous current. In another coil it requires two coils to be kept open for the large current to be drawn. If we connect all in series then very little current would be drawn but it still makes very high magnetic field.
If we put AC capacitors in parallel to the input the current drawn is still reduced. I am actually unable to understand why these things happen but these are easily replicatable observations. I am unable to understand how and why these things happen.  This is not theory or simulation but practical observation.
Input in all these cases is 50 Hz AC. Lowest input used is 105 watts to magnetise to near saturation about 150 kgms of iron.
cliff33
Hi NRamaswami,
      Thanks for that good information.
I just didn't want to go through all the trouble if it didn't work.
  There's a lot of good info. that you won't find in any text book.
  I might try using it on the Figueras device, but right now I'm
working on a Don Smith unit.
