0 Members and 265 Guests are viewing this topic.
bolt
I can understand that you will find those that made KAPAGEN will quickly move on to NST's and the MOTs trashed.  I suspected this a few days ago as running a MOT has TOO many issues.
By going the NST route you will HAVE to learn how to tune each stage carefully because unless there is resonance you get ZERO out to power the lights.
vrand
Quote from: woopy on June 16, 2010, 03:12:59 PM
another thing i have a radio on at 10 meters from the kapagen and nothing , no grrrrrbbrrkkkkkk, at all in the radio.
Thank you for the info, keep up the good work!   :)
Are your spark gaps are really close?  Do you see sparks or an arc between the gaps?
Thanks, Mike
vrand
Quote from: retrod on June 16, 2010, 12:57:46 PM
Some numbers & a A.
MOT  is a OBJY2
Input Voltage : 120vac
Input current : Measured at output of variac 4.0 amps avg
Load: Six 200w 120v Lamps
Earth Grounds : First: 200ft iron pipe (water well). Second: 10 ft driven rod, copper clad
Spark Gap : Champion J-14 with neo magnet attached
Air temperature was 68 degrees Fahrenheit
MOT Temp at start 84 F
MOT Temp at end 107 F
Run time approx 4.5 minutes
http://www.youtube.com/watch?v=n7G60lVJW8Q
Thanks for the update.   :)
What kind of spark gaps are you using?  How do the sparks look? Gap spacing?
vrand
Quote from: What_The_Flux on June 16, 2010, 03:50:50 PM
I'm going to take an entirely new tack on this endeavor. I'm going to try to engineer it the way the inventors tell us to. They make it very clear that a precisely tuned device is essential to getting this effect.
Thank you for sharing your design  :)
Will you be using adjustable spark gaps to "tune it in"?
woopy
Hi retrod
yes  nice job i will also measure the MOT temp as soon as possible on my Kapagen. thanks to share.
woww !! 1200 watt  light bulbs with 4 amps at 120 volts that is to say for 480 watts input
I hope that we can confirm this with other method than bulbs . Any idea for example toaster or ventilator or anything else. ?
@vrand
here the SG,    i use a Bosh sparkplug o.7 mm gap and no resistor and of course it sparks  very well ,,see pix
good luck and night at all   and ring the bells
Laurent
