0 Members and 141 Guests are viewing this topic.
What_The_Flux
Quote from: xenomorphlabs on June 16, 2010, 04:28:04 PM
What_The_Flux:
Check the thread http://www.overunity.com/index.php?topic=7837.0
In particular Peterea and Yucca´s set-ups, which have already experimented in the direction that you are going.
What i don´t understand is ,why you want to divert the experimenters from this thread away from what they are doing and into the Don Smith direction. Especially since they are seeing promising results.
Your approach is very scientific and i wish you good luck in further experimenting.
@xeno
That certainly isn't my intent. My focus is to try to reverse engineer Kapanadze's device.
In fact, the point of my comments were meant to try to steer the forum back to his principles, and what little we actually know about the device.
But I may still be ignorant on some of the subtle differences between TK's work and Don Smith's, so I apologize if I've strayed.
Here is what I'm referring to, from the only actual interview I've seen with Kapandze himself (and what I see little discussion on so far):
xenomorphlabs
Mentioning Melnichenko can be a distraction as well. Barotolougos has actually built his stuff and didn´t run into anything out of the ordinary yet (if i got it right).
I have read his russian patents and this goes radio-technology basically.
Kapanadze mentions resonance yet SR sais the device has nothing to do with parametric resonance, so what type of resonance is there to choose?
People went into all kinds of bizarre theories of transmutation and nuclear resonance, yet no-one has nailed it down.
But i think what you do is good, just trying to proove or disproove stuff experimentally.
dllabarre
Quote from: romerouk on June 16, 2010, 05:52:31 PM
I have used a 1000w heater with fan inside. The heater works ok but the fan part inside burned in seconds. Normally the heater wire is not red because of the fan blowing air but now without the fan it goes red hot very fast.
Success all,
RomeroUK
I plan to disconnect the fan on a similar electric heater I have before I use it.  But I plan to run a separate fan on mains that blows on the heater element to cool the heater element while I power the heater with KapaGen so as not to hurt the heater.  I'll run a test with separate fan on mains and heater on mains to see how the heater will perform when both are powered by mains.  Then I'll switch the heater to KapaGen power and leave the separate fan on mains power to test my KapaGen.
Don
vrand
Quote from: dllabarre on June 16, 2010, 11:33:50 PM
Don
Sounds like a good plan   :)
There is a huge demand for more efficient heating for homes and appliances.
aether22
I was soldering 100W 230v normal incandescent lightbuls together, I decided to see what 8 in series lit up to.
It was barely on, a very dim red glow from the filament but nothing like lit, it barely made it through the frosting.
So each bulb was getting 1/8th of the power it should have, is we do some quick calcs on JLN lights we see that they too were getting about 1/8th the power they would need yet outside they were clearly lit with a white light assuming near perfect efficiency at unity.
Now sure, mine aren't halogen so if anyone wants to try it with halogen go ahead but his are FAR brighter than mine, by a really really long way despite mind being tested inside without lights on at dusk.
Also someone seemingly trying to discredit this breakthrough has said that these bulbs light up at far lower energies with RF, well RF or HV can perhaps excite the gas in these bulbs making them function as florescent bulbs, but JLN's bulbs clearly has white hot glowing filament heated by pure current and resistive heating and no glow gases!
Also any attempt to divert this to the same stuff people have been trying to do and failing thousands of times surely with Smith or normal Kapanadze setups are purely counterproductive and probably sabotage.
