0 Members and 126 Guests are viewing this topic.
woopy
Hi tade congrat for your sharing
i wanted to ask this question to Ossie Callanan but it seems that you already have the answer. that is if i look at your setup you simply use the MO cap  (something around 1 uf and 2100 volts AC )and the MO hv diode as per pix 1 ? is it OK ?
wow !! if i understand you right you had about 6 A for 1600 watts load, and after installing the MO cap and diode, your current dropped to 2.5 A ?
Here under some  suggestion for tuning the SG in pix 2 and 3
succes to all
Laurent
tadejstenta
woopy
i don't now ecsacly if it is 1 uF or 0.95 uf ( having about 10 of them) but both cap and diode is from MO
if you noticed, i had post for first time today ( with 6 amp draw) when i was coming in house, then i saw callanans scheme and i went again out and give it try. I'm was so excited that i was decided to stop test for today or something bad can happened to me ( due shaking hands, ...)
vrand
Quote from: woopy on June 17, 2010, 03:58:45 PM
succes to all
Laurent
Hi Laurent,
The typical MOT HV output is around 2kV so your 2kV cap should work fine as well as the MO diode. Nice spark gap setup   :)
Take a video of the spark gap in operation when you have the time.
Thanks, Mike
NickZ
     2 All:
     If any of you need a simple and effective load or over-load protection source, I have seen how oven heating elements can be used, connecting together as many as needed (3 or 4 ), to help draw and dissipate the extra energy from the electrical source, or device. While the Kws are flowing,  the oven coils are red hot, and so laundry can be dried, houses can be heated, swimming pool warmed, etz.  Or,  they can be left outside to dissipate the energy that is not needed.
  They only cost as little as $22 each, from the following source: http://www.dryerpartsonline.com/4334928-Replacement-Bake-Element_p_445.html
                                          NZ
woopy
Hehe tade
don't worry i can assure you that i was also really "trembling"  in my trousers the first time i switched the kapagen on.  And we have to be very carefull ,as we handle with possibly killer voltages.
be carefull and all success for you.
@vrand
i have to learn the process for the video and utube. But first will i try to speak in pctures for international comprehension. and it works good enough . But i am quite aware that videos is the MUST.
good night at all and good dreamthinking
Laurent
