0 Members and 77 Guests are viewing this topic.
IWD
When you talking about old MOTs from ovens,, remember that transformer are very undersized, the consume is about 1.5-5 ampers without load (depend on exact type) and output is definitly not sinewave
baroutologos
Kapanadze Device vs Kapagen,
IMO, this is in no way similar. Naudin uses two grounds, thus current flows from MOT-coil-load-ground1-ground2-MOT
whereas kapanadze uses only 1 ground and cannot understand how he achieves this current flow. (capacitances is the problem)
Secondly the HV source. Kapanadze device uses too few current at HV just as a part to the procedure. That kind of power could not originate from HV.
Xenomorphlabs, has noted that Kapanadze device works more or less as a poweress device when the two trasistors are plainly operated and afterwards when spark kicks in, full potential is achieved.
See that clearly in the geo.avi (25:10) time. When the first switch is on and transistors/fan is enabled the voltage accross load is 12-16 volts. When the spark kicks in it goes over 200volts.
IMO
We should look Naudin's Kapagen as "Naudigen", since it is unlikely Kapanadze gave diagrams to Naudin and also unlikely that both devices work on same principle.
exnihiloest
Quote from: jermutin on June 22, 2010, 09:20:40 AM
"The input power has greatly dropped to about 153 Watts while the light bulbs are very bright in spite of the surrounding sun light..."
There is a big measurement problem. Due to the diode at the secondary of the MOT, the capacitor is charged only during the positive half cycle, thus the current at the primary is also drawn only during the half cycle.
It is very unlikely that the JLN's power meter could correctly measure power with sinusoidal voltage but no sinusoidal current. It looks intended to measure only regular sinusoidal powers.
MrWolf
bolt is on extremely right track according to my latest research. Ordinary Tesla coil is just a toy because of AC impluses. We need sharp high voltage DC impulses to make electrostatic pump. Effort should go into maximizing electrostatic efficency of the system.
Basic principle is the same as this :)
http://files.abovetopsecret.com/uploads/ats59087_Breast_Pump.JPG
Only we must milk the Mother Earth :D
Good luck!
forest
