0 Members and 225 Guests are viewing this topic.
LtBolo
Quote from: Judges on July 12, 2010, 08:00:46 PM
TBolo,rome,,exine,,,lets stop fighting each other and start doing and shareing.,,,,THAT is what this groupe is about.
Can't comment on other disagreements here, but I'm certainly not offended. Some have disagreed with the emphasis I have placed on some purported technologies, but that's OK with me. I know we all want the same thing, so I simply choose not to be offended.
I am personally struck by what I mentioned in my last post. Specifically, as Q approaches infinity, you can create LMD waves with almost no input power. Not sure about how a receiver will couple to and load the transmitter in the near field, but it seems pretty likely that it doesn't couple and load in the far field...hence...as Q approaches infinity and the resonant freq also approaches infinity, the wavelength gets short enough that the far field can be reached with reduced losses. It seems to me that when the transmission loss at 2 wavelengths is less than the Q of the receiver, you will naturally have a gain. Furthermore, since they are not coupled, you can add additional receivers and multiply power reception, ala Don Smith.
Thoughts?
Pirate88179
Quote from: LtBolo on July 13, 2010, 12:57:39 AM
Thoughts?
And Dr. Stiffler.  With the sec, you can add seemingly as many receivers as you want and the power requirement for the transmitter does not go up.  Jonny Davro has lit many, many leds and ran other devices off of a number of additional receivers with no input power increase at all.
As I have said many times, a good bit of this is over my head but I can see how a lot of these devices are related.
dole
Hi,
What if Kapandze third exit coil is not connected to Tesla transformer just by induction and feed with HV,  in the same time, through spark gap, perhaps this could be Turkish setup and ferrite is used for induction and freq adjustment. I will try this and post if it is any unusual effect.
http://www.youtube.com/watch?v=N7J3ucp5XL0&NR=1
d.
penno64
@Dole
Hi, can you please explain the circuit in your last youtube video re 413353 ?
Many thanks and Regards, Penno.
p.s. what do you think madsatbg is trying to demonastrate in his videos
bolt
Quote from: Pirate88179 on July 13, 2010, 02:02:32 AM
Its as clear as mud:) As told many times Dr. Stiffler is nothing more then a wideband RF oscillator where the o/p is fed into a large series inductor to create near ~ VSWR where power factor has been trashed. Condition creates standing waves where voltage on  his tiny PCB climb to few hundred volts and current on o/p soars.
The tank circuit then SINKS below earth as negative polarity so a diode on these type of systems points towards the circuit and not OUT as you would think conventional. As the ambient RE rushes into to fill the tank or capacitor it refills BACK TO ZERO.
For stiffler just an led that points towards circuit will polarize Radiant Energy which flows into and not out of a circuit. So long as the VARS tank remains intact as Bearden speak "keep the dipole intact" then RE will flow into the LEDS and light them for free.
Many times i explain this that RE = RF conditions where VSWR =~ Now no longer transmit hertzian waves standing waves are electrostatic longitudinal waves. Its not magic just stuff not made clear in text books.
To make electrical OU device (and they are all the same) must create VARS first. In this condition i/p is virtually zero while there is hundreds of volts and hundreds and amps flowing around the tank circuit.  Text books tell you this is meaninglessness and just virtual readings. OH RIGHTY THEN!  So why is it huge magnetic fields appear around a tank of high VARS. = NEWMAN MOTOR.
Only battery is required to give 20 volts or so where 2 tons of copper wire creates a standing wave so no amps required on the i/p of newman motor yet magnetic fields so powerful it spins magnets 20 ft away.
RE = RF applied principles to achieve standing waves where OU enter nodes at ZERO POINT.
Type cold electricity in youtube.
http://www.youtube.com/watch?v=0MchjJy1GOs
Guy on there runs a lamp using cold electricity charged from modified lazer PSU. He shows the difference between polarity exothermic and endothermic electric charge. How did he do this?
Easy. He made HT supply then forced the HT into a L C  to create VARS then the o/p is via a diode REVERSED and charge a very large HT cap with negative polarity cold electricity where the load (lamp) in series to earth.  The power goes up from the earth lights the lamp and fills the cap BACK TO ZERO. Why back to zero? Cos it started with MINUS 10KV. its cold electricity. Notice he uses sealed lead batteries to power the circuit.
99% of you make hot HT sparks you need to learn how to make cold sparks of cold electricity then you might get somewhere on Tesla systems.
PS dont forget now batteries only no mains PSU's can work in most of these circuits.
Don smith coils are not conventional RF tuned they are electrostatically coupled. The VSWR is near infinite which creates several KVARS on his large caps. The caps are charged using a NEGATIVE polarity below earth which is why this circuit must NEVER be powered from the mains only via a battery.
Coupling to o/p stage is magnetic coupling and not electrical flux coupling nor are they RF EM coupled.
The TPU is a large 3 phase tuned tank of KVARS.  When you turn on a 3 phase tank in Power Factor ZERO conditions it takes several seconds to wind up to several KVAR.
