0 Members and 190 Guests are viewing this topic.
kalem
Quote from: dole on July 22, 2010, 07:56:01 PM
Hi,
Please forget Philadelphia “cheesecake” we are not there yet, I would appreciate some help. Does anybody know good and simple schematic or way of getting (buying)  100% sinusoidal variable freq generator up to 20 000 Hz and output around 300W?
Please this is what I found and it could be totally wrong. I think resonance must be fulfilled in the wired itself first i.e. induction capacity and frequency and further I think this is not coincident that Kapanadze use coaxial cable. I suggest those who still experiment to look in to coaxial cable properties, induction capacity and frequency (I think ferrite may magnify this later) probably this is what Don S. is using or primary. I guess Tesla wound this to, documented as twisted pair but in reality one with twisted shied around enlarged later and called Caduceus coil (It is believed that will generate scalar waves).
Thanks
d.
This is not ground cable !!??
Last night I was reading book "Occult Ether Physics" by William Lyne, and on page 104. I found this:
The following concerns a device which appears to unequivocally
disproves Einstein's relativity theories and proves Nikola Tesla's nuclear
theories.
Based on material in Space Aliens (pgs. vii, 185 and 187), a
researcher invited me to collaborate in a 50/50 development of a device
(similar to that shown on page vii), with the provision that I not use his
name. I suggested using an iron pipe and 15 kv transformer, based on
Tesla's use of an iron "antenna" in a Colorado Springs experiment. With
an approx. .1 amp/120 volt input (12 watts), an output of 48 kw was
achieved. Since the K-capture level of iron is 7,110 volts, I suggested
tuning the two 7,500-volt legs to 7,110 with a variac (total voltage
14,220), at which the output jumped to 66 kw, a gain of over 38%.
With 120 v/.l amps/60 cps/14.22 kv going into the ungrounded
device, the output (on the same leads) is apparently superimposed at
high frequency, so that, while maintaining the high voltage 'excitation
electric field', the output can be extracted by high voltage high
frequency filter and rectifier, thence reduced to usable electric power
with an inverter.
In "K-capture", the innermost "K-orbit" electron of iron drops into
the nucleus, converting a proton into an extra neutron. This appears to
render the iron unstable (i.e., "radioactive" in the Tesla sense), so that
it disturbs the equilibrium of and reacts with the ZPR, converting some
of it into an electrical output, via the iron. This device has also been said
to transmute zinc to mercury, when used in a different way to produce
great heat. At this point in time the device is somewhat of an enigma,
which appears to produce great energy.
As the device runs it hums, with no arcing, as a cool shaft of air
exits its top, with strong electric/magnetic fields about it. Some ozone
appears to be forming. This was probably (part of) what Tesla meant
when he said "I have a new use for iron"
FatBird
@ Kalem,   That sounds SUPER!!
Where can we find a picture and an electrical diagram of that device so we can build one?
Thanks.
kalem
Quote from: FatBird on July 24, 2010, 09:27:31 PM
Thanks.
I still don't know. I don't know anything about the author of that book, William Lyne, and I doubt that he will release any diagram of that device, 'cause the book is from 90's and we still haven't seen such device, but anyway, it sounds very interesting, since SR193 used iron core in his little 150 W device. Probably TK also used iron core in his 5KW device. I believe that Kapanadze device is real, not hoax. Right now, I'm trying to "replicate" something similar to SR device. Since we don't have exact electrical diagram, I'm looking for everything that can help, concerning Ether, ferrite core in coils, radiant energy and Tesla "nuclear" theory. All answers are in Nikola Tesla materials, his interviews and lectures. I know it's an "endless" field :))), but that's the only way. And, of course, doing our own experiments. Waiting for electric diagrams from someone could be the easier way, but reality proved that such thing will probably never happen. We have to figure it out the hard way.
CompuTutor
I am downloading both the above books,
and a BBC Horizon video about it too.
The forum attachment size here sucks,
so I probably can't post them here,
but I'll try if I get a smaller set of them ...
I'll see if I can post a few relevant pics,
and any pertinent text quotes if I get a sec.
UPDATE 1:
The full books are about 10-Mb PDF's,
but here is a fair quality mini version.
"William R Lyne - Occult Ether Physics  - 2nd Edition (1997) .pdf"
609 KB (624,402 bytes)
UPDATE 2:
Damn-it, less than half the size of a floppy,
and it is to friggin big, sorry people, no dice !
(300-Kb limit ...)
ramset
Thanks Grandma
