0 Members and 107 Guests are viewing this topic.
Coruscant
Did it run a load or are you just looking at the VAR's as that 400vac at 8amps?
If its VAR's then its nothing till you can extract it to do real work.   I can generate that many vars easy with a rotoverter, but I can't make the VARS do work without causing the lenze effect to kick in and draw more current for any "real" used current doing work on the back end of the alternator.
It sorta looks like you used an RV as the driver for the pole piece you were spinning.
Coruscant
penno64
Hi Bar,
Your comment that no matter how many turns for the inner coil are inserted into the
main coil, it counts as one.
Does this ring true with the slitted pipe insert shown in the russian youtube.
The one where the guys shows how to construct the core with 5 or 6 toroids and a
slitted tube with wire connected to both ends.
Regards, Penno
iws1987
From the intro to the abovementioned paper:
QuoteBy using the product effects of electrostrain and displacement-permeability, a composite containing a bar of Pb(Zr,Ti)O3 and two I-shaped ferrites were developed, and its electromagnetic effect was investigated. Under a constant electric field of 5 kV/cm, about 36% of the electric field-controlled permeability and impedance were observed in a considerably wide scope of frequency. The electric-field dependent inductance and impedance of the composite device showed a ferroelectric relaxation behavior. Analysis showed that the degenerating field-dependent permeability was responsible for the electromagnetic effects observed.
I have now tested the Epcos material "N30" (MnZn ferrite) with up to 7kV/cm.
The coil self inductance is constant despite the change of field strength from 0-7kV/cm.  :-(
There is still the possibility there is an effect, but not in the frequency range used by my LC-meter.
Have one of you bought the report, so we all can know the frequency properties ?
So the question is whether we can buy a ferrite material suitable for this device.
Anyone who knows the type number of the material used by SR193 ?
Eric
sigma16
Quote from: LtBolo on November 05, 2010, 11:09:56 AM
According to Cosmo he built versions that used a ferrite core, as well as others that did not. I have no other confirmation other than Cosmo's word, but he claims to have spoken directly with Kapanadze.
Ask Cosmo to prove the ferrous core.  I am certain that it can not work with a ferrous core.  It is not a  transformer at all.
Cosmo never commented on my picture of the open outer coil on the Kapanadze coil demonstrated in the garden.  This open coil proves it is not a transformer.
forest
Again
Was that video translated to English ?
http://www.youtube.com/watch?v=uxQ99R4gOWY&p=63547D173F4A047A&playnext=1&index=15
Here you see solution and explanation, why not translate if you know Russian ?
