0 Members and 447 Guests are viewing this topic.
Shokac
Quote from: the_big_m_in_ok on November 24, 2010, 04:03:21 PM
(Referring to the drawing on posted Reply #4481)
Have I figured it out?
--Lee
Yes, use Cosmo test shematics. In the right frequency on the HV and LV side, current in the source is smaller  (40%) and bulb light brighter
Shokac
Quote from: forest on November 24, 2010, 01:21:57 PM
I think that sigma16 has given the right answer.Electrons are pumped first from big copper coil (made from tube) into ground and then return when this copper coil is fully positively charged.Then again and impulse of negative HV is inductively charging copper coil into positive HV potential and electrons escape ito ground via thick stranded wire.
Hmm..the same could be truth for SR device, just copper tube replaced by ferrite core with a stranded wire tap directly on it. Can someone confirm if SR device had a wire supposedly tapping directly to ferrite rings ?
Maybe yes, maybe no. In 100kW Kapanadze device don't have ground. Kapanadze says that in this device use Y-load 3-phase circuit, and center is N. (No Ground)
Mr Kapanadze tell us which principle you use in the installation.
This copy is based on the well known law of the lever.
How does, we take a small portion of total energy network using Tesla coils get hundreds of thousands of volts and send it through the spark gap on the current amplifier.
The principle is identical to the lever.
Correspondent.
Mr Kapanadze we are well aware that the lever worked he needed a fulcrum, where it is in your setup?
You're right, in my installations up to this, I used ground, which is rapidly destroyed by the processes occurring in the soil around the pin. Ð'
In this installation, I compensated by the lack of three-phase inclusion of a star.
Correspondent.
Others:
http://next-energy.ru/forum/index.php?topic=40.msg5752#msg5752
iceweller
from http://next-energy.ru/forum/index.php?topic=40.msg5752#msg5752
translated to English (well, nearly - google translator or bing do what they can):
"Mr Kapanadze however that this pipe, which has a spark? There are rare and radioactive elements?
  No there is not that complicated. This magnetic separators of machines pipes, inside of which the coil of copper wire. And that's all!"
Another translation goes:
"These are pipes magnetic separators from machine tools, inside of which coils from a copper wire"
A magnetic separator pipe from a separator machine or just a ferromagnetic material?
Magluvin
Quote from: iceweller on November 24, 2010, 07:27:07 PM
So his core material is outside of the output coil. Well thats different.    8ll8  Like a circuit symbol in a schematic, not a typical transformer.  The coils are isolated from each other and the shield is the shared core for transfer.
Mags
