0 Members and 551 Guests are viewing this topic.
energia9
Quote from: baroutologos on November 27, 2010, 04:24:13 PM
@ energie,
I have been thought about this. Actually i have developed a thread http://www.energeticforum.com/renewable-energy/5392-ground-based-energy-systems.html
in energeticforum.com about the possibility of extracting energy from earth via resonance.
The point is to be there energy to be extracted, in oscillating current mode of considerable "voltage".
Assuming that eath's telluric currents hum max at 500Khz frequency, then it will be a matter of design in how to tap them effectively.
Unfortunately, we have not any indication that the earth's currents are in this frequency range and are "strong" enough for achieving meaningfull magnification via resonance. (and power extraction consequently)
By the way, it requires some investigation to see it yourself
Thank you Bart,
i will continue to explore, and now in high voltage, because my previous experiments were all low voltage, 0.4 volt input,   now i will require more than 3000 volt and im building the powerful signal generator for making the same setup with 500khz,  i shall see interresting results,  i will explore and explore may be i will quiten now because im too tired, will return with fresh things to show you soon,
Thank y
iceweller
@barautologos - I checked out your thread and I believe the direction is correct and I wanted to point out a few things that were also pointed out by amigo. Tesla's wireless system was based on several concepts which I see many misunderstand or misinterpret still today - but this is off topic. In the case of ground power transmission he used the earth as a one wire conductor. He wanted to pump the pulses from the Wardenclyffe in the earth at it's resonating frequency (he said in an article that wavelengths of 6000meters were acceptable and 12000 meters would be ideal (50 and 25kHz) so these could be picked up in any place with the equivalent equipment. He wasn't mentioning any OU but very high efficiency (enough to keep the oscillations running and cover the losses). However Tesla also stumbled onto some additional discoveries (after Colorado Springs) which he mostly cryptically mentioned in his various articles, interviews (new use for iron, self acting oscillator etc) and especially announcements. These are the ones that most interest me and which I have tried to correlate for the last decade - it appears easy, but I assure you it's not, especially with the different views and opinions "modern science" (that is after 1930) offers. The wireless power system Tesla "officially" offered was alternative to the ordinary wire system and cheaper as already pointed out but this is not related to this research. What is, is his let's say "electrostatic" research that interested the later part of his life which is what is evidently (re)emerging lately with these experiments. It is the combination of HV coils and charge induction or transfer or "electro kinetic" effects as sigma put it that must be investigated. The way I see it is that we must use this effect to leverage a natural law for our advantage (create a "sink" for these currents to rush in etc) however I am not sure that telluric currents are really enough for these effects though they may be involved.
   I must however suggest to everyone the Tesla article collection by Ratzlaff called "Tesla said".
  Good effort everyone!
nievesoliveras
Thank you @iwd!
The pdf file was blocked by my machine's defense. But I could download it today. It is on the list of pdfs to read now.
By the way I found on a sidewalk five flyback transformers. None of them are equaly configured. I mean the flybacks say different things for the same pin number.
Eventually I will catch it. I just need two of them to work in order to make a test on feed back.
Jesus
baroutologos
@ Icewellwer,
I am not familiar with Tesla's work on electostatics, but i can understand wireless power transmision via earth.
I fully agree with you, the Low frequency typical 20 or 40Khz will limit the Hertzian EM losses. Moreover an arbitrary choosen ground projection frequency will not go very far. As Tesla repeatedly said, there are frequencies that the earth "responds".
He argued in one of "Tesla Said" articles that he can maintain a huge oscillation of earth's potential at the expense of few horsepower losses at the correct frequency.
I do not take those words as misinterpretation. Making a HF oscillator that excites the earth and hence transmits energy with little losses worldwide is a possibility for me. No OU there btw as Tesla said.
The point is, HOW you can know who is draining power? Your destined clients or your rivals? A global energy transmision systems, even perfectly made and unless energy is for free, will not work ever. All will intercept and steal the power projected. Plain and simple.
The point is what if the earth creates electricity of herself that Tesla has not discovered. At what frequencies? (Telluric currents)
This research is well beyond my present capabilities.
Magluvin
Tesla was working on small portable receivers in his apt lab in his last days, that didnt require a transmitter.
Mags
