0 Members and 590 Guests are viewing this topic.
Pinoy_Tech
Quote from: Shokac on November 26, 2010, 04:36:52 AM
Question:
How radio receiver can listen to one radio station?
Can a radio transmitter to know how radio is receiving its frequency?
What is the purpose Tesla coil?[/b]
Hi Mr Shokac, Can I ask you about your experiment? Did you tried to observe if there is any difference between "with Earth gnd and without"?
By the way, on your above Q's;
- there is a tuning frequency know as local oscillator usually clapp colpitts osc to tune the incoming freq. Radio is working on superheterodyning process.
- Normal radio communication (Tx) can't monitor if there are receivers recieving its transmitted freq signal, they are just propagates everywhere and disappear in atmosphere. (radio intercom techniques like satellite phone does monitor)
- Tesla coil? Are you referring to ant?.. Just to recive any electromagnetic waves with certain specific freq and feed to rf amp.
forgive my short ans, it's my old understanding wayback '86..
thanks,
jronel
Shokac
Quote from: Pinoy_Tech on December 02, 2010, 12:37:22 AM
thanks,
jronel
Currently I'm working on something else, but I tested one of my theories and shows good results. The next part that I need to do is a source of very high voltage (15-30000V).
If you look at this video you will understand what I'm talking about.
http://www.youtube.com/watch?v=WNnLU50VS0o
It measures the voltage on the device when you turned on the HV source and when not.
Try with wire antena and with ferrite antena. (AM)
Look this theory: http://translate.google.hr/translate?hl=hr&sl=ru&tl=en&u=http%3A%2F%2Fut27972.narod.ru%2FBook_2%2F85_Book_2_part_85.htm
And connect everything together with Frank Prentice device
baroutologos
Has Anyone noticed the striking resemblence of Frank Wyatt Prentice Patent and Don Smith's devices?
It is almost obvious to me now, that DOn Smith copy/paste devices utilizes the same schematics (even though it uses only 1 ground in all) and makes also the same mistakes.
http://www.free-energy-info.co.uk/Chapt5.html
Here is a schematic of Prentice's patent.
Note transformer 8. Its a stadard Tesla HF oscillator. Those involved in coiling will readily perceive that the spark-gap possition is totally wrong there. It should not be between mains and LC circuit, rather than "shorting" the cap via coil upon suitable voltage rise.
Patrick Kelly, www.free-energy-info.co.uk/Smith.pdf , presents The diagram of Don Device, having the same possition (even though replaced by a voltage arrester) and instead of an induction coil (9) Prentice has, he puts diodes to the two NST output cables.
When explaining DOn Smith's Table top device Patrick tried unsuccesfully to justify the weird possition of the spark-gap (that was copied by Prentice patent) and says a long story of erroneous stuff.
Tried and know. A spark-gap in this arrengement produces a spectrum of frequencies, and produces a very very very weak LC oscillation. A waste of energy in other words.
Take another published of Don device (posted few pages before - photo2) and compare it with Prentice. Clearly it resembles prentices antenna in a sense.
Take another published device, Photo 3. There DOn smith uses a NST of HF and then starts explaining with tremendous incaccuracies and errors how FE is produced. Compare that with Prentice's (27) HF receiving transformer and observe carefully what the variable cap performs (33) and how the cap bridges / steps down voltage or even frequency perhaps (or frequency modulation in a way) to motor (38) via transformer (35) that can be an iron core one!
Don tried to conviced people with giving a chart from America Radio Association that this step down and frequency alteration could be achieved with a variable RESISTOR across the output iron transformer.
What's your oppinion gentlemen?
Shokac
Quote from: baroutologos on December 02, 2010, 03:16:22 AM
Patrick Kelly, www.free-energy-info.co.uk/Smith.pdf , presents The diagram of Don Device, having the same possition (even though replaced by a volatge arrester) and instead of an induction coil (9) prentice has, he puts diodes to the two NST output cables.
When explaining DOn Smith Table top device Patrick tried unsuccesfully to justify the weird possition if the spark-gap (that was copied by Prentice patent) and says a long story of erroneous stuff.
Take another published device, Photo 3. There DOn smith uses a NST of HF and then starts explaining with tremendous incaccuracies and errors how FE is produced. Compare that with Prentice's (27) HF receiving transformer and observe carefully what the avariable cap perform (33) and how the cap bridges / stesp down voltage or frequency perhaps? to motor (38) via transformer (35) that can be a iron core one!
Don tried to conviced people with giving a chart from America Radio Association that this step down could be achieved with a variable RESISTOR across the output iron transformer.
I wrote about it recently
http://www.overunity.com/index.php?topic=7679.msg265227#msg265227
baroutologos
@ABove,
It maybe look like Kapanadze device but it certainly looks like Don Smith's ones.
Look at Prentice issued patents. http://freenrg.info/Patents/EARTH/PRENTICE/FWP_Inventions.htm
The man says, that his principle object was inventing a way for train signalling back then and accidentally discovered power from earth...
