0 Members and 27 Guests are viewing this topic.
iceweller
@ wattsup - in the latter part of the video, they disconnect the thick black wire from the faucet and connect it to the second white gnd wire connected to the buried radiator - if you check my previous posts, I also mention the exact time - he used one gnd connection at a time - he switches in order to show a different gnd connection that they made beforehand.
  In the last part of the video they show a book and a printed document. The document is a paper by Oliver Nichelson on Tesla's "Fuelless generator and wireless power transmission". The 2 pictures show a bifilar pancake coil and the other is a cut section of Linde's condenser - you can verify this yourself by checking out his site or downloading his paper in pdf format (though Oliver confirmed this to me himself):
http://home.earthlink.net/~drestinblack/generator.htm
or here
http://sites.google.com/site/teslanichelson/home
  Regarding TK's vs SR's setup, well they have two different "entry" stages: TK feeds the "green box" with 220V from the inverter/UPS output stepping up the 12V while SR "boots" the oscillation with a 15V DC source, then from what I could make out, stepping the output back down with a small trafo to 12V and rectifying it similar to TK's black box. What really counts is the coil setup/winding coupling.
  Additionally I don't think the output is 50 or 60Hz (low Khz range is more likely) which is why in these setups/demos there is only a resistive load like a filament lamp - though it cannot be a very high frequency as transformers are used to step back down the output (possibly ferrite core).
forest
according to Tesla the upper limit is around 30 khz,it need to suppress EM radiation
baroutologos
  Regarding TK's vs SR's setup, well they have two different "entry" stages: TK feeds the "green box" with 220V from the inverter/UPS output stepping up the 12V while SR "boots" the oscillation with a 15V DC source...
It is commonly anymore to believe that Kapanadze and SR's alleged device is the same or share same working principle.
IMO, SR has nothing to do with Kapanadze and according all indications the chances at having a working device are far less than those of Kapanadze.
After all, how Kapanadze managed to silence SR and vice versa?
Not to mention that (as previously mentioned a couple of pages before) Kapanadze allegedly has called SR charlatan ! LoL.
Anyway, go figure...
@Iceweller,
It has been suggested that Kapanadzes green box operates on 50/60 Hz arbitrarily. IMO it operates at low frequencies since amp clamp meter can meter!
By the way, i have devised a 555-timer that operates an inverter setup, and i know my cheap amp-clamp meter can have a marginal accuracy at most 1-2Khz.
After 3-4 Khz does not show anything, despite of course current circulating at same amperage more or less.
(see photo, left the 555-pulser kit, setup a standard NPN-PNP (BDX53c,BDX54c) and two 50uf AC caps)
iceweller
@ barouto
  From what I could put together, SR didn't really call TK a "charlatan" - this seems a translation error. It appears he said "babbler" (a slang word in Russian as in other languages) meaning that he likes to talk a lot, but not in the sense of talking the false or to discredit if you see what I mean.
  Regarding the clamp meter readings of TK's video I still think the output is not a clean sine: the output could be a composition/superimposition of a modulated (damped) wave train as was suggested in some russian forum (which would be filtered by the clamp meter resulting in a readable sine, being a low pass filter). Some analysed the SG sequence (honestly, digitising a VHS footage to avi from 25fps to 30 messes with the original sync so I don't know how they are certain about this) and said it is a "train" of impulses @50/60Hz possibly triggered by an oscillator inside the green box. They even made a schematic showing a sort of rotary SG inside the box at some point.
  Some other russian (tiger2007) is showing some interesting replication attempt which left me slightly baffled though I have been unable to properly translate the footage to understand his basic steps.
   Naturally I take everything with a grain of salt. I try to analyse and correlate and discuss (unfortunately for now I have no possibility to use my lab or instrumentation). At first it appeared that the 2 devices were really different, but now I think their basic modus operandi is similar if not identical (they access the same "source" at a certain frequency o harmonic thereof).
  I think you have put in a lot of effort and experimenting (as others) and I see you have been onto this subject for several months on various sites/portals trying to get more information - keep up the good work. This of course goes to everyone, we must keep the spirit high and collaborate constructively!
wattsup
Can I just get one major point across. You absolutely need an Earth ground on one side of the bulb or load you are driving. Then play with the positive side only.
I have done some tests last night with my 0 awg wire going to my house piping. By the way, my house piping comes in as 3/4" thick copper type but it stops there after into plastic piping so the house is not creating an effect and there are no other devices grounded to the piping.
My main comparison is the tests I had done in my "pulsing coils and lighting leds" videos. I have not seen so much performance on the leds with only my positive going from my pulse generator, no negative. Just that one wire and the other side going to Earth ground. I hit a major effect at around 2100 hertz.
I cannot say it more directly. All experiments should include a Earth ground to one side of the bulb or led or load. I will try this again during the weekend but this time with a real bulb and  a mosfet through my power supply to find the right frequency-width. This is not as complicated as it seems.
Also, there is not much more to see in the TK video. I also have the annotated SR youtube video now transferred to AVI format so I will use VirtualDubMod to try and make a real wiring diagram of his set-up. He was very generous with the videoing angles so I can get in real close.
But Earth ground on one side of the load is the prerequisite starting point otherwise you will be working with the wrong final effect.
