0 Members and 114 Guests are viewing this topic.
LtBolo
Quote from: penno64 on December 20, 2010, 12:38:35 AM
Would you not consider the transformer to be a flyback - seeing so many pinouts ?
Yeah, probably. If we had the specs on the particular flyback that would be real handy.
p.s. what voltage rating would the bank of caps be ?
Since he's ganged a bunch of 15nF caps, I'm guessing they are quite high, and to get the earth to yield a good current, I'm sure they would need to be. Obviously can't tell from the schematic, but I'm sure we are talking about 1000s of volts.
LtBolo
Quote from: baroutologos on December 20, 2010, 03:03:25 AM
Interesting line of thinking. By the way, as i see it, the particular experiment of 2 capacitors does not resemble earth capacity. Actually as i see it, earth and an insulated metal object is one capacity and not 2.
Also, If you put in series two earth grounds and a capacitor, it will resemble almost a dead short to capacitor rather capacitor to capacitor connection. In order the analogy to be true, earth somehow should possessed already a difference of potential that is exploited. (as the large cap has in your experiment)
I used the term 'capacity' instead of 'capacitor' intentionally, to distinguish between a 2 pole device vs a 1 pole device. When I hold a screwdriver up to a Tesla coil and it starts discharging to or from it, the Tesla coil obviously 'sees' the screwdriver as a source or sink of electrons...a capacity. When I shuffle my feet on the carpet and then discharge to a ground, I too am a capacity. In that sense, the earth is a capacity and the coil is a capacity...whether or not they have 2 plates and a dielectric between.
I am not claiming that my 2 cap experiment is exactly the same as what we seek. I am suggesting that the 2 cap experiment gives us a peek at how a strong charge gradient will behave...and specifically...it will cause more charge to travel from the source to the sink than the sink can contain. If we believe that the earth is a source of great capacity, and it either sources or sinks lightening strikes so I'm pretty sure that it is, then if we can create a localized potential lower than the earth, then we can cause a mini lightening strike into our coil.
As for two grounds...yes, I agree with you...but only as a static system. With impulse currents, a 12 inch piece of wire looks like a coil. Two grounds widely separated definitely do not look like a short to impulse currents.
angryScientist
It looks like the Modulator Amplifier and the Modulation Coil form a resonant circuit and the generator is  forming a beat frequency with it. So the high voltage former is what causes a net direct current to flow through the output, if I am seeing that right.
The output is a high frequency with a tendency to flow with a predominant current in one direction during half the beat frequency and simply oscillate back and forth normally during the other half of the beat. The DC component is introduced by the HV Former when the oscillations reach a high enough potential to break down the spark gap. It only reaches that potential during the "loud" part of the beat which is set at 50Hz by setting the Generator to a difference of + or - 50Hz from the natural frequency of the Primary Oscillator (which is the Modulator/Amplifier plus Modulation Coil).
Ingenious how he retards the natural swing in flow by shoving it backwards as soon as it is sensed in HV transformer #3. Why didn't I think of that before?
Wish I would have seen that schematic earlier. Everything is packed up and it looks like I going to be homeless for who knows how long.
baroutologos
It is my understanding, Ltbolo, that either an obvious two plate common capacitor or earth and an elevated globe, its the same. They both form a two plate capacitor, no matter how small the capacity is or bizzare their outline is.
Nevertheless, i have some expectations also, that two distant ground points in "inpulse currents" or "resonant mode" will not behave as a dead short, or a dead resistance. We will see by experimenting :)
energia9
Quote from: forest on December 20, 2010, 07:38:01 AM
Seems related to Richard Willis patent. He found a way to turn on/off neodymium magnet by a bifilar coil around it with a HV spikes. Up to 50kW output.
May be related to what Hubbard and Hendershot found and also to Tesla car.
Just a few cents  ;D
hi could you please post a link to this Richard williams patent,  thank y v much
energia
