0 Members and 18 Guests are viewing this topic.
hartiberlin
Quote from: Pirate88179 on July 01, 2009, 02:20:22 PM
Stefan is correct.  In all of my earth battery efforts, without any JT circuits, I can get about 2.5 volts but it is the amps that are elusive.  I am not sure of the wattage of those 5 bulbs but even if they are only 25 watts each, that takes some serious amps to get them to light...way beyond anything I have been able to achieve thus far.
@ Stefan:
I believe that blue box is nothing more than a simple battery charger.  I am guessing they are using that in reverse as I have read that is possible to do?  I have seen folks do similar things with the wall chargers for cell phones and other devices.  They feed 9 or 12 volts into it and get 120 volts out the other side but, this does not account for the amps.
Hi Bill,
this does not work,
as otherwise it must be a real inverter with a oscillating  50 or 60 Hz circuit to transform
the DC up to 110/220 Volts  60/50 Hz AC.
A battery charger will not work just used in reverse without modifications.
But maybe they just modified a battery charger, so it converts
12 Volts DC to 220 Volts AC  or just a higher DC Voltage output ?
WHo knows...
hartiberlin
hartiberlin
Did anybody notice in the first video
http://www.youtube.com/watch?v=Mxa_G4X8Y7k
at minute 7:25
the guy is hooking up the cables by twisting.
Can one see, if all the burried cooler copnnector cables
are unisolated ? Are these just pure copper strands without isolation ?
hartiberlin
What are they measuring at minute 7:56
in the first video:
as 0.64 Volts ?
Or is it 6.4 Volts ?
Probably not.
0.64 Volts sounds realistic for just a potential difference between
the iron ? water pipe and the copper cable being burried at the cooler grill...
This then is just the galvanic voltage between these 2 different dissimular
metals.
Okay, so I have to watch now again the other parts for the other meter readings
to be shown...
hartiberlin
Okay, I had a look now at the original video,
but unfortunately it is not much better in quality.
Anyway, the
schematic connection picture already posted is right.
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=35467
In the first experiments there is no cooler grill connected.
Just one ground connection to the water pipe !
(maybe they have the burried cooler grill connected in parallel with the
water pipe, so it gives them a better ground connection ?
Could have been out of the video area, so you only see once the
connection to the water pipe...)
So it seems to be a pretty easy circuit.
Just some sort of Tesla coil, looking to be 2 coils, one with many turns
and the second with just 6 turns,
where the first many turns "high voltage coil" is
energized by the green box with high voltage pulses ( bursts)
via the spark gap and then the output of the high turn coil goes to the
light bulb bank(all bulbs connected in parallel) and then back to the
low turn 6 windings coil and then to ground.
It looks like they are pumping somehow the free electrons from the electricity from the ground
through the bulbs and then to the attracting positive pole at the spark gap.
Maybe they have been canceling Lenz law in their special series circuit of this
special Tesla coil ?
The black box with the 4 cables is just a special impedance transformer with a rectifier circuit in
there to  transform a bit of the output AC power back to the
inverter DC input.
Thus they really achieve a selfrunning circuit this way.
The light blue metal box seems to be the inverter from 12 Volts DC to 220
Volts AC.
It seems to be a dual function device which could probably also
act as a battery charger cause it also has a nonconnected 220 Volts
connection cable attached to it, which is not used in the video.
But the battery charging is not used in the video, it just only
acts as an inverter to transform the 12 Volts DC from the battery
to 220 Volts AC.
This video is really challenging, cause it really shows a selfrunning
system putting out around 500 Watts of free electrical power just
plugged only into a water pipe as the ground line.
Amazing !
