0 Members and 192 Guests are viewing this topic.
Yucca
Quote from: flathunter on July 20, 2009, 05:57:18 PM
Maybe me too Yucca!  I was thinking the exact same thought about the swing.
The video that was posted by SH and Bolt, with the Russian guy and a tesla coil, illustrates your point perfectly.  Its just wireless transmission.  No OU.  I can do the same right here with a small lamp.  Perhaps Kapanadze and Donald Smith know something that I dont, but a lot of Donald smiths devices (for example, the dipole transformer generator) seem to be suggesting that any (magnetically???) resonating coil will give OU - and all you need to do to catch it is have a capacitor plate at right angles to the magnetic field - this will generate more power than input, as it will catch the heaviside component.  Thats what i read anyway.
At the moment, i'm not convinced....but i'll certainly keep trying as its lots of fun!
I want to add a doorknob capacitor to my tesla coil primary to increase the capacitance.  I have a polypropylene one already in there.  Is this OK to do??
It sure is fun to do, a hell of alot better than watching the telly box.
Yes my point about resonance is that I don´t think it´in itself is a source of OU, but it maybe a necessary component somehow, I´m not sure. I think as you mention capturing the elusive heaviside component sounds more like a possible source.
You can parallel caps with different ESR I think it should be fine, maybe it will cause slight non linearity, i.e. resonance point will shift ever so slightly with different avg drive powers, but it probably won´t be noticable.
My research at the moment is with cored devices, when that´s done I will probably build something like whats being discussed here. But I like reading this thread and so will probably stick around a little.
bolt
Well depends what is normal??
Most people that make tesla coils do it for pretty sparks and low frequency but the REAL Tesla  purpose is for energy management and that is what he is doing here. For that you need high volts he could have >250,000 here looking at that coil gain and it at least 20khz which is what you need to do this properly.
BUT for Don smith systems you don't make 3000 turn coils such extreme volts are not required and parts to handle such extreme voltages such as FWBR  are almost impossible to find thus DS systems tend to have 5 to 100 turns depending on the stage gains and frequency transpositions required.
The type of spark though is what you need it should be a HF violet corona hisss across a very small gap will stop electron flow. If it makes a cracking popping sound thats low frequency and very wasteful.
Proceeding RF stages then are re-energized with a FRESH supply of electrons from the ambient and NOT from the source.
Quote from: ramset on July 20, 2009, 08:54:11 PM
bolt,
the flame/spark/plasma coming off the wire in this vid is normal Tesla stuff??
http://www.youtube.com/watch?v=qqiYDxMsayw
Chet
ramset
Thanks Grandma
bolt
"Yes my point about resonance is that I don´t think it´in itself is a source of OU, but it maybe a necessary component somehow, I´m not sure. "
Read tesla patents read don smith notes they both explain what it is.
There are a few methods to pull free electrons including Iron banging.   HF iron banging creates crystal magnetconstriction within the iron where iron actually becomes a fuel and iron molecules disintegrate! This is a powerful effect draws qauntal noise (free electrons) if you hit the right NMR frequencies. Matter is converted to energy on a tiny weeny scale it disappears I think it reappears somewhere else in the universe as you cant destroy it but everything is always in transition there is nothing static.
There are at least 20 patents on this technology that i know. Many said the TPU works like this but i think its very unlikely.
If you read 1930 -50's books they tell you about the "Electron Theory" and that's what electricity is only a theory not reality. Zero Point and Ambient ether whatever is left out of mainstream. Then Electron-Engineers were born to make sure the story sticks.
No point denying it any more  you seen the Kapanadze and TPU in action plus many others. :)
flathunter
Quote from: Yucca on July 20, 2009, 09:35:50 PM
Hi Yucca!  Thanks for the tip.  But I thought I would double the capacitance of the primary circuit by adding a capacitor, so i thought this would change the resonance point quite a lot - perhaps i'm mistaken?  I thought that I'd be able to increase the spark gap distance with more capacitance, and increase the volts on the toroid, with longer prettier streamers in result.  Again, perhaps i'm mistaken???
@Bolt.  Thanks for the interesting replies.  Less turns sounds good, as I've bought a sewer pipe and some wire to make a receiver coil....i'll get building later today after playing with the extra doorknob capacitor.
Good luck to everyone on this thread!
