MrPayback
I will lead by example and see if our Russian friends will join us.
The Kapanadze device and the SR device use the same ferromagnetic principle in spite of some have wrongfully claimed. The ground wire running up through the center is what is called a 1 turn transformer and it will transfer mostly the back EMF to that ground wire. Without it, the coil would build up a huge charge and be dangerous or destroy the electronics.
Another way you can tell they are both ferromagnetic is how they are driven. On the SR device schematic, you see a chip that is driving the transistors. If you look at the image below of how the chip is wired, you see what appears to be a Schmitt trigger or a chip operating in that way.
The reason the chip is connected like that is to produce a random or wavering sound similar to a siren. You can search youtube for hex schmitt trigger and find all kinds of noise makers such as this.
http://www.youtube.com/watch?v=Nh8UnocB5KM
The reason they are using the changing sound is because when a ferromagnetic transformer goes into saturation (necessary for the effect to occur) the resonance point of the transformer suddenly changes.
Both Stan Meyer and Dr. Puharich wrestled with this problem. Meyer solved it with a phase locked loop while Puharigh solved it with a feedback from the secondary.
The Russian devices are primitive so they are solving the problem by driving the transistors with a range of frequencies to hit the ferroresonance harmonic of iron or the sweet spot enough to keep it running.
CosmoLV posted a 556 driver circuit recently where he did not show where the triangle wave went. (It's a big secret you know...) The triangle wave is used to vary the frequency driving the transistors which will help hit that moving target.
Another aspect of ferro-resonance is that when the ferromagnetic resonance occurs, the core itself will emit lots of voltage and so it must be grounded. You can see how he traced the copper ground plane on the wire to show it's location.
http://www.youtube.com/watch?v=oY8Pmm1mwYM
The ferromagnetic material will go from Fe65 > Fe54 and give off two electrons. When they come back, this pulls the coils lower and energy is produced.
If the ferrite contains non-conductive dielectric piezo electric materials such as silicon dioxide, the ferrite will resonate even better and produce what Meyer was probably calling "electron bounce phenomenon" which will enhance the effect.
Other methods can be employed such as using a shorted coil to produce a reflection and magnetic compression which results in acceleration. Even a permanent magnet on the end of the coil which is probably what that part that sticks out on the end of the Kapanadze and SR coil is, will produce some compression and bounce resulting in acceleration and excess energy.
Here is an example of gotoluc playing with what appears to be the magnecoaster principle:
http://www.youtube.com/watch?v=zQxL9W6gVG4
So all that and probably more proves that both Kapanadze and SR are getting their energy from ferro resonance. Both the claimed driver circuits and the ground wire running through the center are evidence of that.
Here is the driver for the SR device and while I stated it was probably a hex schmitt trigger, other chips can be used. Meyer used a programmable pulse train set by dip switches for example.
Note how on the SR193 schematic he calls that section of the schematic "sine wave deformation"??? That is to make sure to hit the sweet spot.
MrPayback
Quote from: stivep on April 07, 2011, 05:50:51 PM
Well thank you for your post.
Very well done.. patriotic, american, very much open,
with good taste, not overdone but pointing the power of USA
This is what I say about it
me "the complainer"
So what I complain about if at the same time I can appreciate
your writing   ..........
and
what is that you appreciate about my writing while you complain about my  writing?
Think about it...... and I will Be back
Wesley
Ps: Philosophy is the mother of science
Wesley,
I appreciate nothing about your writing. This is a science website, if you want to complain about the US, I suggest you do that elsewhere.
Otherwise, please keep it on topic or you hinder our effort.
Thank you,
MrPayback
MrPayback
Here is a link to a 556 timer circuit that will produce a varying signal to drive the transistors similar to what CosmoLV alluded to.
http://www.electronics-project-design.com/PoliceSiren.html
stivep
Quote from: MrPayback on April 07, 2011, 04:09:34 PM
The computer you complain about the US on was invented and most of the parts in it were manufactured in the US. The internet you use to tell us how stupid we are was invented by the US and connects the Earth through space based communications placed there by the US. The forum software is open source and most of it written by Americans and given away free to the world. The database that stores the data for this site was written by MySQL was created free and open source by Americans.
I agree with you.
notice:
-Russian are the ones first in space.
-computer was build not invented in USA as modern computer only!! by John Vincent Atanasoff, (1903â€"1995), United States â€" modern digital computer
and he was
The son of a Bulgarian immigrant
http://webcache.googleusercontent.com/search?q=cache:aanIpXXXBGYJ:en.wikipedia.org/wiki/List_of_inventors+invention+of+first+computer+in+russia&cd=1&hl=en&ct=clnk&gl=us&source=www.google.com
if you take names on that list for all of these important inventions you have  o God...by the letter A  only one american wow..............Bulgarian American ................. :)
God bless America.......
and
11 Russian
(for your record:
-Edwin H. Armstrong,(1890â€"1954), U.S. â€" FM radio was English man)
-Robert Adler, (1913â€"2007), Austria/United States â€" wireless remote control was Austrian)
and Nicola Tesla was not american born
Can you point me just one American/american ??????, just one by the letter A??????????????????
QuoteYour freedom from communism came after US president Ronald Reagan went on TV in front of the world and challenged your dictators to "tear down that wall".
that is controversial we believe that was Polish "Solidarity"
movement that started the fire similar way as it is going on i Middle East but thank you............Sir.
QuoteDuring the cold war, over 80% of the high technology Russia did obtain came from the US through secret deals made by Al Gores father who was a US senator. Al Gore is a communist and the God son of Armand Hammer who was a Russian capitalist.
When you have approximately  of 270 or so Russian scientists inventors per one American born one than it is hard to believe in that. But  Only God know.
Ratio 270:1 I might  be incorrect you count.
QuoteWhen your communist government collapsed, it was the west that loaned you the money to rebuild your society and develop a economic system based in mutual benefit rather than submission and exploitation. You failed at that.
Yes I agree... and taking big profit out of it.
QuoteAnd now you come here lecture the west about how we can't fix bikes and refrigerators and complain that it is illegal for you to dig through our trash.
inventor of refrigerator Eastern Europe
Carl von Linde, German
http://www.ideafinder.com/history/inventions/refrigerator.htm
inventor of the bike:
French
Pierre and Ernest Michaux,
http://inventors.about.com/library/inventors/blbicycle.htm
So sir Don't fix your refrigerator or bike ..there always will be Russian or Polish who can do it for you.
QuoteMost people think time is money but that is wrong. Time is art and what you do with your hands and minds with your time on this Earth is your art. If you share your art, the Earth and your country get better. If you spend your time trying to steal others art you only wind up poor.
I agree with that part thank you.
QuoteIf you suppress the art you do create and try to make the big score, you most likely wind up with nothing like Kapanadze and you live and die angry and poor. In the end you only helped your worst enemy.
Well partially true  Philosophy:
"Object" oriented individual is programming  Philosophy of crowd by him being part of the crowd.
If "Obiect"  essentially represents goods and goods are available without of significant effort, than   crowd does not starve for progress.
That's why Eastern Europeans have build Ham Radio Transceivers while  Americans  just spend  their money to buy it.
Wha was than more knowledgeable person and/or community??????????
..... so do not fix your bike Sir just buy  the new one !!! each ..right!!!!
QuoteAmericans and the EU are different. We tend to cooperate with each other through mutual exchange and benefit system. This is why we create what the world wants and needs and people like you, want and consume it. This is why our countries are developed and secure. This is why we don't have wars and revolutions on our soil. This is why life is easy for us but we work hard doing things we tend to enjoy. This is why we don't move to Russia and dig through your trash.
No comment this is for me  radical especially the last sentence.
QuoteWe allow you post on a web site and complain about us anyway because we have a great deal of love. You see all those things that we created were all created out of a love to make the world a better place and that made us better.
For your record
1.I'm in titled to freedom of speech
2.I  do "not complain" so to say/or per say
but rather try to bring facts not rhetoric.
3. your words in this par are full of pain I understand  you  and agree but only to the neutral part of your complain.
QuoteThe craftmanship of SR and Kapanadze looks like the work of a child. They do not have the love to even create something that is organized and well constructed. They use a knife to cut wires and attach them without connectors. They use cardboard painted green as a housing. Everything from the poor conditions with how they live to what they create lacks love.
This part is outrageous  Sir  are you out of your mind?
You discriminate person based on his  poor society status?????
And this man can create that what you can not with all of your wealth and tools and money
And you talking about LOVE???????????????? Sarcastic!!!
So Tesla if he never go to USA will be considered by you
Quotequote:
"They do not have the love to even create something that is organized and well constructed"
QuoteWhat has the Ukraine (SR-193) or Republic of Georgia (Kapanadze) given the Earth? Nothing. Anyone that did have any love, left that those hell holes a long time ago.
wow........ you going wild.........Sir......... You exposing your true nature.....not the loving one.........
That means that Tesla was poor and recognized only after his death and (in regards to wireless) only Marconi Company did not win rights to invention but Tesla (after his death)
because USA did not want to pay for use of this technology during 1WW
QuoteSo continue fixing the bikes you get from our trash and fixing  your own refrigerators and if you want to join the rest of the developed humanity, you will need to let go of your fear based emotions and express your love if you have any.
How do you want me to comment this discriminatory statement
I have love  to you too :) As a human being.
QuoteUntil then you will play "I have a big secret" to try and impress people or rip them off but the only people that buy into that are not worth knowing because they are just like you. There are a few OU forums in Russia. Why are not not posting there?
There is Us Americans dinging in Russian forums because the "fixing bikes" Russian are of value to you Sir.
You do not even speak Russian Sir. Ho can you Judge Russian who  understand English almost everyone especially From new Generation.
Do not dig in it Sir............ and Do not   fix the bike... just buy it
QuoteYou can't form a prosperous and advanced economy by ripping each other off. That best describes what Russia is trying to do and is the reason they have failed and will continue to fail.
Yes I agree  but as the education level they are extremely well educated  FACE THE REALITY SIR!!!
QuoteIntelligence is born out of thought integrity and courage springs forth from love. Truth is the measure of that love and I loved you today by telling you the truth.
Beautiful words thank you
Wesley
stivep
 Thank You for exposing yourself Sir
Population of Russia 141,850,000 -
Territory 604250 miles
Population of USA 307,006,550
Territory 2959064.44 square miles
Russia is twice size of USA
Russia has   half of the American population
And with that population
of twice less people ............Russia is holding ratio of scientists inventors based on the link  above 270 Russian scientists per  one American  one.
Face The Reality SIR!!!
Wesley
The mentioned approximation is based on official list from link above.
from the other hand:
Mr Payback:
glen............ what the hack we arguing about........
You are one of the most valuable brains in here I can see that  by few words of yours.
You are one of the big  assets ...
I do not like your attitude you do not like mine but
besides that.. Man... I respect you as the source of knowledge
Why we are getting into conflict...
