xenomorphlabs
Quote from: LtBolo on May 05, 2011, 05:20:34 PM
Only in a 0.5 Tesla field. NMR is expressed as frequency per Tesla and is not a fixed frequency.
Which is a very strong field and the additional requirement of at least 150 degrees Celsius (!) according to the patent.
This was already pointed out by Baroutologos some time ago:
http://www.overunity.com/index.php?topic=7679.msg238691#msg238691
A while ago, a couple of russian experimenters have tried to heat up the ferrites for this to work, but with no success.
LtBolo
...and actually, I misspoke. The NMR of iron is not 21Mhz at 0.5 Tesla, that is the frequency of a proton. The frequency of iron is considerable lower.
I'd say that the heat allowed a reduction in the excitation energy, but that is speculation.
AbbaRue
The following article found on page 35 Of Lyne's book "Occult Science Dictatorship"  may be useful to others
in regards to this subject.  Here is the quote from page 35.
If the number of neutrons in a disintegration product (the atom
transmuted to) is too small compared to its number of protons, the
nucleus will tend to reduce its charge by one unit by positron
emission, and will always have 1 Mev less kinetic energy than if beta
decay had occurred.8 Since a light element (below atomic number
19) will transmute in U.V. light, radioactivity in light elements can
be induced very easily. When Joliot and Curie bombarded aluminum
with alpha particles, they observed that neutrons and positrons were
emitted. When they removed their alpha source, the positron
emission did not cease, but decreased exponentially with time, as if
the aluminum were a naturally radioactive element, for a period of
three minutes.9 The positron will always carry 1 Mev kinetic energy,
and may be used for energy production. Since this process can be
effected by use of an U.V. incident particle beam on the light
elements, and will produce positrons at 1 Mev of kinetic energy, it
may be used in what I call "leapfrog technology", which can be used
for transmutation processes which will manufacture elements in
much greater quantities than could be effected by the huge
accelerators at such places as U.C. Berkeley.
Based on the Tesla Primary Solar Ray theory, using the Kcapture
process, this is my explanation for a device I call
Free Energy Surprise (© 1997, Wm. R. Lyne, ISBN 0-9637467-6-6, $10.00,
Creatopia Productions, General Delivery, Lamy, New Mexico
87540, Tel/Fax 505-466-3022), a technical report which includes
a set of plans and documentary photos.
I got the idea for this device from a statement by Nikola Tesla,
concerning "special" uses for iron, to capture the ZPR/Primary Solar
Rays. Whether or not this is exactly what Tesla meant, I believe it
verifies his statement concerning special properties of iron.
The device, composed of steel pipe and bar stock (about 10
lbs.), is stimulated with a 15 kv, center-tapped transformer. It
operates in several modes, but in what I call the "hum" mode shows
an input of 35 watts and a secondary activity of 42.6 kw, operating
at or beyond the approximate K-capture voltage on each leg, ca.
7,110 volts (the K-capture voltage for iron), at the standard 60 cps.
The low frequency current goes into the mass of the iron (not a
'skin effect'). The iron seems to be going to manganese and back to
iron, 60 times per second. This idea is based on what appeared to be
the appearance of a purple area near the top of the pipe which I
recognized to be the color of manganese dioxide.
The extra electrical energy might be the product of interaction with the ZPR, the ether
(neutrinos?), and the iron. Since manganese is the next element
down on the periodic chart, with the same mass number as iron, it
sounded like a reasonable hypothesis. The voltage is not really
critical, as the effect could occur so long as the voltage passed
through the K-capture voltage on its way up and down, and is only
supposed to cause a somewhat more definite effect when it is right
on the "absorption edge".
It appears that the electrical energy in the secondary output
circuit can be converted into usable electrical energy, especially by
using a resonant transformer, tuned to the same, 60 cps frequency.
wattsup
@All
Last week my computer gave out. The motherboard went and I just changed my computer and migrated all my usual programs and everything else from the old drive to my new drive. Except now it is an i7 with 8gb and 1TB with great graphics fully loaded under XP-PRO64 with a great 23" screen. Needless to say, it was not long before my VirtualdubMod was up and running again and this time with a much bigger and clearer screen.
Here is something I did not see before. This one observation just elucidated many of my questions about the TK coil.
- I was right about one of the coils having to be single strand because it is in series with the spark gap.
- I was wrong about only one wire going to the TK coil.
- I was wrong about the overunity being in the green box, it is in both.
- The TK coil is picky backing on the spark gap through one coil while the green box outputs to the load through the miss-mash the spark gap is generating while the green box outputs. Both lines are isolated.
It's like making minced meat. While you add the meat parts, the mixer turns and makes the meat homogenous. WOW. I will have to make a block diagram this weekend.
wattsup
PS: Maybe this will get us to page 500 - lol.
Shokac
From Kapanadze:
Question: What are you showing us today?
Answer: This is a device which draws energy from the environment. It draws 40 watts as it starts up, but then it can power itself and provide an output of 5 kilowatts. We don't know how much energy can be drawn from the environment.
this is TRUE!!!!
