0 Members and 200 Guests are viewing this topic.
Magluvin
Quote from: wattsup on October 14, 2011, 11:47:47 PM
As one of them said the output is one wire. Y'a man.
Those two diodes after the HV are producing half wave rectification output meaning the load on the HV is cut in half and the output now has half the time and space for resonance. At resonance, this produces high frequency high voltage reactive. But I see a waveform showing 4khz. Then I see this one shown below. I wonder what frequency this is.
wattsup
If you look at it  another way...
Its not half wave rectifier.  ;]   The transformer below, the primary and sec have capacitance. That is the path back to the other side of the source.
I have a vid on YT a while back when messing with AV plugs. I was able to complete the circuit on the can of the car ignition coil. But there I had cap path using the can(isolated from coils) as 1 plate and the working coils inside as the other.
Anyhow, it is full wave.  ;]
Even if the cap is limiting the path, the path is there. ;]
Mags
TheCell
@stivep : I could only partially figure out , what Aidas explained.
Maybe you could you could tell us in more detail:
<my questions>
5:36 Aidas: We have had the ???? caduceus coil
?? aronas ?? heat is the dissipation of energy so at that point we can
reverse the heat that will bring us energy ??? before.
..paper between this two pieces of ?? than see what then happens
___________________________________________________________
At 6:06 <I don't see any windings crossed ; is this a caduceus coil?>
<looks more than 2 bucking coils of a smith device>
At 7:00 so again we have had 2 plastic rods devided by a piece of paper
in horizontal ?? in caduceus coil
<How does this look like?>
At 7:53 <not a caduceus coil ?!>
<What frequency is the primary LC resonance circuit tuned to?>
energia9
SPECIAL THANKS to Wesley and the team to help me realize how the circuit works.
all people will soon start questioning the governmnent, if this is that simple why we have to suffer from their stupid ignorant global warming taxes and lies when it is not even existent, we know and we will act!
TARIEL KAPANADZE we will help you! we will!!! you are a great man, the stars eyes are on you, you will get better and heal
PEACE AND LOVE TO EVERYONE of you!
T-1000
Quote from: TheCell on October 15, 2011, 06:47:19 AM
We have caduceus coil http://drblayney.com/images/jbwnd.jpg
The heating ferrite means dissipation of energy so we needed to make sure it does not happen(I am Arunas ;) ). To stop Eddy currents we did put paperclip for insullation of ferrite rods there so no more energy was going outside of the coil. By the way, with our setup this phenomena was only in the middle point of entire primary coil.
Again, the primary is caduceus coil, the 2 secondaries are right hand + left hand coils. Please see how magnetic spinning forces work in http://freeenergynews.com/Directory/Magnets/Leedskalnin/Magnetic-Current_Edward-Leedskalnin_51pp.pdf You need to follow rules of mother Nature there because this is a way how everything works from single atom to big galaxies in cosmos.
These 2 secondary Tesla coils looks almost exactly like in D. Smith device.
When you have 2 pieces of ferrite, attach insullation on their junction point. Also you need to find out distance between them for best efficency (imagine them as 2 magnets doing work for you with zone of moving bloch wall)
The flyback transformer resonance was about 16 kHz. After spark gap we get wide range of frequences what hit secondary coil resonance harmonics. After this excitation you have moving mass + fields doing work for you.
Hopefully that helps :)
