0 Members and 168 Guests are viewing this topic.
Jimboot
@electricme Jim that is a great idea. I was wondering what I was going to use for that.
thanks (from another aussie Jim)
frantz
Hi all friends,
I'm new on this forum but I would like to ask about construction of caduceus coil.
For ex. when we wind caduceus coil and after we connect HV to this coil we will to have HV on to ends of coil. Distance between two ends of coil (2 wires) will be 2 x insulation thickness.
Question: Which type of wire (isolation) we should to use to create caduceus coil...???
regards
Jury1
Thank you for video.
what is the black wire coiled on the right  hand side that is coming from behind, down to the rear of the  table?
Right  hand side , bottom of the monitor?
Please post schematic of  parts and connection.
Interesting but it would be nice to get more  info
Can you show closer waveform ( shape of waveform)
what is the frequency of oscillation?
What is pick to pick voltage of oscillation?
What is multi meter -  type ( model number)?
What is range of DC V switch  to?
What is internal resistance  of multi meter?
What is the model number of transistor?
@ Wesley
The black wire coiled is  probe improvised oscilloscope…
Recently, my hobby is «open systems». Often have unexpected situations - equipment failure.
My family budget does not allow each month to buy a new oscilloscope.
Therefore, I made the oscilloscope of the computer sound card. I use a program " Scope".
Scheme of the experiment -
http://xmages.net/storage/10/1/0/7/0/upload/2b7f1e43.jpg
I use the n-p-n bipolar transistor - 2SC3461.
Frequency of oscillation - 15,6 kHz.
Internal resistance  of multi meter  not affect to work of the transistor.
Important detail is the secondary coil of the transformer
She has resistance - 340 Ohm.
Where to get the powerful diodes?
http://www.youtube.com/watch?v=QnQoJxirLJY
leo48
QuoteFrequency of oscillation - 15,6 kHz.
In european PAL system about 625 lines for frame and 25 frame for second
625*25 =15625 row for second = 15625 Hz ;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
energia9
T-1000
are selenium high voltage diodes good?  i bought vintage diodes which were from old televisions,  they can handle 20kv 500 ma  they are selenium diodes
check this peeps:
http://wiki.4hv.org/index.php/High_voltage_diode_-_50_kV,_30_A_peak
hehe
