0 Members and 176 Guests are viewing this topic.
Hope
I read a report recently and I WILL find it and post it.   They made a IRON pipe react with a center rod with high voltage on it.  They slowly ramped up the HV to the reactance level of the iron particles and gained over 1082% output over input in 1957 (or around then).  So it would seem perhaps the coil is the antenna and the iron reactance is the generator.   When I find this article again I will post the link.   It seemed like the frequency was around 14,220 K
TEKTRON
Quote from: Jury1 on October 28, 2011, 08:28:45 AM
I am interested in the question - How safe are my experiments?
I felt a physically ill when this device has worked…
To verify the  presence of radiation, I brought a solar panel to the lamp. In sunny weather, it gives a maximum of 6 V DC, I saw the 1200V ...
http://www.youtube.com/watch?v=FrK6SgHlAZA
Now, that was very interesting! What type of radiation do you think is being emitted? And is that a real voltage being generated by the solar cell or HF noise screwing with the meter? Do you have an analog meter you could try and redo the experiment? Thanks for sharing! 8)
DimaWari
Good Day Guys.. I think you should put your spark gap inside the glass, this may help suppress the radiation
From other Planet
Yes measuring radiation is a very important point to not harm humans or animals near the device, including yourself.
I am also very interested in your solarcell radiation measuring experiment. Can you explain it little bit?
As we are dealing with OU devices, we dint really know about percentage of "wasted" energy emitted as different radiations or sideeffects of these phenomena producing harmful radiations, or even extreme spacedistortions bad for health.
Think most people have no possibilities to measure this, we need a solution here and to be careful.
Hope
Found lease costly radiation detectors at Goldmine Electronics.
Comment if you can read this????
