0 Members and 110 Guests are viewing this topic.
T-1000
Quote from: verpies on November 16, 2011, 05:01:05 AM
Do you mean this one? :
Is your device still working (15W in and 150W out) when the copper strip is as wide as the height of the yoke ?
The optimal was half heigh of yoke. With full heigh we still need to finish testing, it is not confirmed result.
Obviosly FCG PCGU1000 has no protection on output and we accidentaly burned it again. Now it needs to get repaired.
P.S> After yesterday's conversation with Tiger, he got mirrored site in http://freeenergylt.narod2.ru/aidas/tiger/
verpies
Quote from: itsu on November 15, 2011, 06:32:18 PM
Ok, looks like i found something looking like a ferrite resonance point around 1 Mhz.
I will do some further testing the next days.
That's good news that you found a stationary peak.
The potentiometer is connected correctly. I only did not like the long red wire with crocodile clips that connected the two windings to the scope ground.
I am surprised that the potentiometer movement had no effect.  What is its resistance?
If it has too low of a resistance then it will have the same effect as shorting the 15t & 50t windings together and these two windings will just resonate together.
Also beware that the signal from the 50t coil has much higher amplitude which simply overwhelms the lower signal from the 15t winding, possibly making it unobservable.
Also please note that a rectangular wave is good for ringing tests because it has short rise and fall times but sine wave is better for the high frequency sweeping tests.
Rectangular waves produce infinite amount of odd harmonic peaks on the spectrum analyzer.  Sine waves produce only one peak, thus they do not clutter the display.
The small differences of frequencies that you observe between your experiments are most likely due to the varying width of the "paper gap".  Paper swells with humidity and can also "work" mechanically as it is squeezed.
Did you see the new oscillogram from the inventors?
It seems that now they claim that the wider the copper strip - the better.
verpies
Quote from: stivep on November 15, 2011, 07:19:52 PM
New "delivery" is on its way.. just wait around 1.5 hour.
Did you translate the long video from Russian to English ?
Where is it?
T-1000
Quote from: verpies on November 16, 2011, 05:26:06 AM
Where is it?
http://www.youtube.com/watch?v=8xnq62SSg84
It is not professional translation but at least will be something worth to look at :)
verpies
Quote from: baroutologos on November 16, 2011, 04:02:33 AM
Anyway, white noise or not, potentiometer or not, analysing the 15turn coil or 50 turn or even a copper strip as a winding etc that particular 1 Mhz ferrite resonant frquency should be there under all circumstances and with some tinkering will become too obvious to be ignored.
Yes, if there is indeed a frequency peak, that originates from the ferrite or copper strips and not from the LC resonances of the sensing windings, then it should remain stationary.
The peak should not move sideways even if the sensing windings are detuned with a picofarad variable capacitor in parallel.
