0 Members and 357 Guests are viewing this topic.
T-1000
Quote from: jbignes5 on November 17, 2011, 12:36:24 PM
Collection should be on both sides of the ferric ring using bifilar winding so that each field can be extracted from each side of the surface they created with the HV pulses then swirled via the copper winding. When this is done they will see the true power that these fields contain.
That needs to be confirmed or declined by experiment. But only after you get first half like our team did :)
Jdo300
I would say this site here seems to offer a very relevant discussion of what we are working on... Almost identical if you ask me:
http://amasci.com/freenrg/a-vect2.html
- Jason O
baroutologos
Quote from: verpies on November 17, 2011, 12:41:47 PM
Yeees.
This is a highly unconventional behavior.
Conventionally, the high impedance of the 15t coil @ 50Hz could be explained with a very high effective inductance, most likely caused by very high permeability of the core.
...but we know that the core has very low permeability (see Osiakosia measurements) and Itsu's experiments show how the low frequency waveform from the signal generator collapses when shorted by such low inductance (low impedance) winding.
The only non-sociological explanation is that the other perpendicular windings do something to the the core material to increase its effective permeability dramatically.
Nice potentional explanation of the fact that FG are not affected by the 50Hz @ Kv range voltage, but again makes no sense to me. If that core pearmitability would increase daramatically allowing no current to "move" at 50 Hz, how the bulb is lighted at the end? Obviously by current.
Try connecting FG leads at mains. Will they be burned? :D
jbignes5
Quote from: T-1000 on November 17, 2011, 03:12:26 PM
Yes I agree. But as you know Tesla did most of them experiments already with a working device. However simple it may seem he did it already. You just have to look at his style of experimenting. Also one needs to remember that most patents are not complete. They merely point out the basics. That was the patent I showed you by Tesla. That system of self generation of high voltages into high voltage field coils shows how he was negating The Lorentz force which doesn't show up when High voltages are used. Simply having the high current coils exposed to the high voltage fields negates Lorentz force through induction. So there is no feed back to the high voltage generator or exciter in the patents case. The rotor is the high current coils and they soak up all of the high voltage fields in that process if it is balanced correctly.
Also Tesla seems to have shown that high voltages don't need a return wire either. The mass of the receiving coils if balanced properly will allow for all high voltage field to be converted with little stray field left over. Of course this has to do with two different metals. Aluminum= very efficient transmitter of high voltage/shield if not connected to anything (floating ground) and copper= converter for the high voltage field based on inductive capabilities of copper.
The secret seems to be where you use the metals in that patent. Field/emitting=aluminum wrapped around circular Ferris or iron core and copper wrapped around Ferris or iron core= field collection. The orientation of the collecting coil is also a clue. 90 degree angle always from each coil. Same goes for the emitter field cores. In this patent you can see it all in action even a self driven portion.
http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
Even though this patent has distinct parts it can be included all in one device. It is a steady state motor and when you change that state by loading down the rotor or check the speed it forces the rotor coils to amass a great current in it. This of course can be fed back into the drive section or motor. The rest can be connected to another ring to convert the up and down undulation of that surface into a positive feed only, to be used in another section of the vehicle.
The timing is all automatic in this patent the only other thing that could change the operating parameters is the mass differences between the two metals and surface area as well of those coils. Get those right and it auto tunes to a steady state. Try to slow down the rotor and bingo the copper coils cut more whirling lines and generate tons more current. Spin the rotor in the opposite direction of the lines and they put out huge amounts of current, hence the motor drive.
If you read the patent it tells you this is not the AC system they would like you to believe it is. This is the improvement to that system. This was to be our answer to the energy crisis. He left it for us.
grizli
Quote from: semenihin-77 on November 17, 2011, 12:43:22 PM
Mini powerful experience DINATRON
http://www.youtube.com/watch?v=QImgCHFXYa8
whats the purpose of this device dynatron schmatic is posted before, I do not see load ?!
