0 Members and 23 Guests are viewing this topic.
Kator01
Hi verpies, hello all
can someone verifiy and help with translation about this here:
http://www.youtube.com/watch?v=mgYpwQM2U34&feature=uploademail
Kator01
Kator01
Quote from: Kator01 on December 20, 2011, 12:05:36 PM
Kator01
Discussion here :
http://www.001-lab.com/001lab/index.php?PHPSESSID=9efbd4bf12e60aa610ddf881244b5bfa&topic=639.5150
Man with the curled-pattern-pullover is destine. I simply mirror here what a russian speaking german user of overunitty.de posted today. He is not giving details however.
Kator01
Osiakosia
Quote from: Kator01 on December 20, 2011, 12:17:11 PM
Discussion here :
Kator01
Hi Kator01 ,
On this video was represeted the Don Smith devise replica . The person near Destine is Sergey known by nick Dynatron  the main producer of this replica . This device is based on
air core tesla transformer . All major parts   device you can find on www.001-lab .com .
At present time Sergey-Dynatron is working on harvesting module of this device .
verpies
Quote from: wattsup on December 19, 2011, 03:16:38 PM
In your last video "Delamorto replication 2.mpeg", when you raised the black coil that is connected in series with the bulb, the bulb got dimmer.
This for me means that there is a very high probability that the Tesla coil is not really inducing anything into your black coil
Wattsup could be right or when the bulb got dimmer, the black coil was over the node of the standing wave in the "Tesla coil".
In standing waves - nodes have minimal amplitude and antinodes have the maximum amplitude of oscillations - by definition.
Apparently the load (or antenna at the output of the "Tesla Coil" ) has very mismatched impedance and this causes strong reflections of the pulses back through the "Tesla Coil" acting as a transmission line.
These reflections create standing waves in the coil, that Baroutologos was detecting with his neon screwdriver.  See his quote below:
Quote from: baroutologos on December 12, 2011, 09:08:09 AM
...observing coil's standing voltage with a screw driver, the voltage antinodes stays more or less the same
utube video: http://www.youtube.com/watch?v=Jxp6wrh2Pqo
These results with the neon bulb screwdriver, remind me of the old Hams that put a light bulbs across their feed lines.  See:
http://www.youtube.com/watch?v=w1eE13UXAKs
http://www.youtube.com/watch?v=4vdSP-580Vw
P.S.
Itsu, you've got a personal message in your mailbox
jbignes5
Just for giggles.
http://books.google.com/books?id=h2DTNDFcC14C&pg=PA53&lpg=PA53&dq=tesla+gave+westinghouse+new+soft+iron+for+transformers&source=bl&ots=Zm1CWtIqNJ&sig=45LUOiILnWtR3_0fWQYHo1CcjYk&hl=en&sa=X&ei=4-zwToubI-Ho0QGZpsWMAg&sqi=2&ved=0CFkQ6AEwBA#v=onepage&q=tesla%20gave%20westinghouse%20new%20soft%20iron%20for%20transformers&f=false
Lets really look at what Tesla was up against and even Morgan turned his back to him when he found the improvement to the AC system. Morgan couldn't charge then for the power because he had little to do with maintaining the system. He would have zero residual income and thats what Morgan thrived on. He wanted to create a commodity and the original system could allow him to do that. Meters everywhere. Tesla's improved AC system was the key to opening our Humanity up and give us all the power we needed for any purpose.
Unfortunately we are addicted to this consuming mindset. We crave energy and waste it in great displays like in Los Vagas. We burn tons of fuel to get our stuff around when we could just hook to the real speed of our Universe is flowing and conduct any amount of energy we need for merely standing here.
We are not seeing the true mechanics of the universe and only chose to focus on the mechanics that we can charge for access. We need to start reading about the real truth of the situation when Tesla was battling with The Corporations. They are the ones responsible for demeaning all our Humanity by charging for anything to do with that humanity and yes that means our beliefs as well. Read the link and see what the Corporation does to each of us and of their own.
http://www.uoguelph.ca/~antoon/tesla/Tesla.html
Tesla: "I will be quite explicit on the subject of my magnifying transformer so that it will be clearly understood. In the first place, it is a resonant transformer, with a secondary in which the parts, charged to a high potential, are of considerable area and arranged in space along ideal enveloping surfaces of very large radii of curvature, and at proper distances from one another, thereby insuring a small electric surface density everywhere, so that no leak can occur even if the conductor is bare. It is suitable for any frequency, from a few to many thousands of cycles per second, and can be used in the production of currents of tremendous volume and moderate pressure, or of smaller amperage and immense electromotive force. The maximum electric tension is merely dependent on the curvature of the surfaces on which the charged elements are situated and the area of the latter. Judging from my past experience there is no limit to the possible voltage developed; any amount is practicable. On the other hand, currents of many thousands of amperes may be obtained in the antenna. A plant of but very moderate dimensions is required for such performances. Theoretically, a terminal of less than 90 feet in diameter is sufficient to develop an electromotive force of that magnitude, while for antenna currents of from 2,000- 4,000 amperes at the usual frequencies, it need not be larger than 30 feet in diameter. In a more restricted meaning, this wireless transmitter is one in which the Hertzwave radiation is an entirely negligible quantity as compared with the whole energy, under which condition the damping factor is extremely small and an enormous charge is stored in the elevated capacity. Such a circuit may then be excited with impulses of any kind, even of low frequency and it will yield sinusoidal and continuous oscillations like those of an alternator. Taken in the narrowest significance of the term, however, it is a resonant transformer which, besides possessing these qualities, is accurately proportioned to fit the globe and its electrical constants and properties, by virtue of which design it becomes highly efficient and effective in the wireless transmission of energy. Distance is then ABSOLUTELY ELIMINATED, THERE BEING NO DIMINUATION IN THE INTENSITY of the transmitted impulses. It is even possible to make the actions increase with the distance from the plane, according to an exact mathematical law. This invention was one of a number comprised in my "World System" of wireless transmission which I undertook to commercialise on my return to New York in 1900."
