Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
tishatang
Stubblefield cont'd
The bifilar coil helped.  But no way did it do what he wanted.  He finally realized if he wound a collector coil around the bifilar coil, it would sum all the high voltages and the high amps together.  So, we end up with the collector coil as supplying the power to the load.  This explains the three coils in his EB patent and where they are connected.  Remember, iron wire to parallel circuit.
tishatang
Stubblefield cont'd
All these experiments have the  coils on the surface.  The only things in the ground were his ground rods (plates).  NS had one more refinement to try before he built this config as an earth battery.  He got the idea to prime the config with a vibrating relay.  Actually, he may have thought of this after he built the EB and buried it in the ground?  He found that by priming  the pump, so to speak, it increased the output.  Probably because the collector coil was also a resonant circuit and the relay was vibrating at the resonant freq of the output coil?  The arm of the relay (make or break) could be a rod with a small weight that could slide a up and down.  This would give him the ability to fine tune the pulses of the relay to the res freq of the collector coil.  I think he would have worked this all out prior to burying it into the ground.  Stay tuned for the rest of the story.
Zoky
@tishatang
Dude they all use ground (earth) becouse ground have super conductivity and you can use that on all planet earth. Basicly you always have one polarity (-) ready for use and second like i first say. One more think you can use earth for transmition too that Stubblefield prove and Tesla talking about that more times.
I read everything about Tesla here but find very low text and links about that ..people scared to
experiment with tehnology what tesla working but im pretty sure it is way to clear free energy :-).
MW383
Tishatang,
Very interesting posts regarding resonant circuits. I made a few scratchings on you latest picture. Can you comment? I am still coming up to speed with this subject. Thank you.
,MW383
tishatang
@MW383
I am glad you are interested in this.  Your added cap does not contribute anything.  Notice that you are bridging two plates that are both negative.  Both plates will have the same potential.  Caps are added to isolate separate circuits with different DC potential.  AC will pass thru a cap depending on its size and freq you are trying to pass thru.
Since the two bottom plates are at the same potential, you could tie them together and use only three ground plates.  Circuit shown below.  The var air caps are shown to show how to connect to your plates to experiment with series and parallel resonance with your ground plates.  They would not be there in Stubblefield's time.  Also note that the cap in the series plate side will block any DC component of the earth energy.  The cap shown in the series output circuit is there to obtain resonance of the collector coil.  NS did use large caps.  Here is quote of chapter:
"A second series of experiments reveal the development of stacked capacitors. Photographs reveal two large capacitor stacks, presumably for inductive transmission purposes. Some researchers induced ground oscillations of electrical current, while absorbing each "fly back" into large capacitors. This system evidenced the "hydraulic" model of electricity, popular during the latter Victorian Epoch."
